Go to Post We figured it out. - benjiengi [more]
Unread 02-18-2014, 01:23 AM
Joe Hershberger Joe Hershberger is offline
National Instruments
AKA: jhersh
FRC #2468 (Appreciate)
Joe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to all
Re: Using atan2 on the cRIO
Originally Posted by MaraschinoPanda View Post
Whenever I try to use the atan2 function by including <cmath>, I can compile, but I get "no robot code" and netconsole gives the message "Warning: module 0x26eaa80 (FRC_UserProgram.out) holds reference to undefined symbol atan2f." If I use std::atan2 or atan2f, or even just try atan, the same error occurs. I've also tried using <math.h> instead of <cmath>. All compile, but none are defined. Does the cRIO not have trig functions in its c++ library, or am I doing something wrong?
I think the problem is not the header you are including, but the library that is not loaded. It is possible that the function is not compiled in, but that would surprise me a bit. Perhaps there is a separate library that needs to be loaded.
