Go to Post With FIRST, its all about style! In the northeast, we are alllll style. - Andy Grady [more]
Unread 17-02-2014, 17:11
William Kunkel William Kunkel is offline
Programming Lead
AKA: Kunkel
FRC #0422 (Mech Tech Dragons)
William Kunkel is an unknown quantity at this point
Using atan2 on the cRIO
Whenever I try to use the atan2 function by including <cmath>, I can compile, but I get "no robot code" and netconsole gives the message "Warning: module 0x26eaa80 (FRC_UserProgram.out) holds reference to undefined symbol atan2f." If I use std::atan2 or atan2f, or even just try atan, the same error occurs. I've also tried using <math.h> instead of <cmath>. All compile, but none are defined. Does the cRIO not have trig functions in its c++ library, or am I doing something wrong?
Unread 18-02-2014, 01:23
Joe Hershberger Joe Hershberger is offline
National Instruments
AKA: jhersh
FRC #2468 (Appreciate)
Joe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to all
Re: Using atan2 on the cRIO
I think the problem is not the header you are including, but the library that is not loaded. It is possible that the function is not compiled in, but that would surprise me a bit. Perhaps there is a separate library that needs to be loaded.
Unread 19-02-2014, 13:15
DjScribbles DjScribbles is offline
Programming Mentor
AKA: Joe S
FRC #2474 (Team Excel)
DjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to behold
#include "Math.h" is likely what you are looking for
Unread 19-02-2014, 17:05
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
Yep. On a normal *nix machine, you have to add -lm to your link command to use the math library. I expect this is the same thing in Wind River.
Unread 20-02-2014, 18:14
Programming Lead
AKA: Kunkel
Huh, I was unaware of that. I'm surprised I haven't come across this before.
Unread 20-02-2014, 20:05
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
That would not be true in this case. The .out file we load on the robots is a relocatable object that is dynamically loaded and linked into the VxWorks kernel space. So it works like adding a kernel module in Linux, not like an executable and library in user space. It would be true if we used real-time processes (RTPs) in VxWorks which are much like processes in Linux but we don't. I think support for them is not included in the kernel we are provided.
Are you sure it is atan2 that is not being resolved? It should be there. The OS image includes the GNU math libraries and we have used atan2 before in field-centric driver algorithms.
Good luck!
Unread 20-02-2014, 21:41
Whenever I try to use the atan2 function by including <cmath>, I can compile, but I get "no robot code"...
If you still haven't been able to get the library atan2 function to work, and you need something to tide you over until you can get it figured out, here's a simple C code implementation that's good to within 1/10 of a degree.
Unread 22-02-2014, 09:15
taichichuan's Avatar
taichichuan taichichuan is offline
Software Mentor
AKA: Mike Anderson
FRC #0116 (Epsilon Delta)
taichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud of
Send a message via AIM to taichichuan
Hmm... We used the atan2 function in the 2010 bot with no problems. A quick check on the bot shows both an atan and an atan2 in the symbol table. From the netconsole prompt:
-> lkup "atan"
atan 0x000b5218 text
atan2 0x000b542c text
The actual addresses are not important. But the "text" shows that there are funtions out there with the names shown.
Make sure that you include math.h and reference the function as "atan2" not "atan2f". WRS has the double precision version of the function on the bot.
HTH,
Mike
Unread 29-05-2014, 01:20
jrw jrw is offline
FRC #4774 (The Drop Bears)
jrw is an unknown quantity at this point
Lightbulb Re: Using atan2 on the cRIO
For anyone hitting the same obscure problem here is the answer.
I note from the github repo of the OP's code that they are using the C++11 toolchain from FirstForge. We haven't used the original toolchain, only the C++11 toolchain too, so it might only affect those teams using this.
Anyway, the problem is that the compiler substitutes the float version of trig functions if it thinks you don't need the extra precision.
If you have:
float f = atan2(float x, float y)
then the compiler will substitute this for the atan2f function, and this is not on board the cRIO.
Change your code to:
double d = atan2(double x, double y)
and it will be plain sailing. Even casting the floats to doubles as you call the function will work.
