Go to Post Of course, every team in FTC should be asking the magic question: "What would Simbotics do?" - Billfred [more]
Unread 18-02-2014, 08:35
DMike
Posts: n/a
Problem with Auto
Our auto program won't run correctly. We are simply trying to drive forward and fire a piston. once in a while it runs fine, but then the drive motors wont fire but the piston does. We are using the WPI mecanum auto VI in Lab view.
Any ideas?
Unread 18-02-2014, 08:36
Nick Lawrence's Avatar
Nick Lawrence Nick Lawrence is offline
Commander Canada
FRC #3940 (CyberTooth, AndyMark)
Nick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond repute
Re: Problem with Auto
Are you using encoders on your drive, or a timer?
If you're using encoders, are you resetting those values to zero before you start your auto mode?
-Nick
Alumnus of 1503 Spartonics
Founding Mentor of 5406 Celt-X
Mechanical Design Mentor of 3940 CyberTooth
Emceeing events since 2013 - come say hi!
Success doesn't always equate to match wins. It's about the wins off the field.
Unread 18-02-2014, 08:49
jmartin jmartin is offline
AKA: Joseph Martin
FRC #0172 (Northernforce)
jmartin is on a distinguished road
Is motor safety enabled? (If you haven't explicitly disabled it, then it probably is). Are you getting any errors on the driver station/netconsole?
The motor safety feature will stop running the motors if you are not constantly feeding it values for motor speeds, and will say something like "Output not updated often enough" if you set the motor to full speed once, and then wait a while and stop it.
Unread 18-02-2014, 08:58
geomapguy's Avatar
geomapguy geomapguy is offline
Centenary '18
AKA: Graham Maxwell
FRC #1818
geomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud of
Especially if you are using a Jaguar
The Cowboys - FIRST Robotics Team #1818 2015-
The Bolton Bear Bots - FIRST Robotics Team #3666 2011-204 (30-26-0)
2014 Oklahoma Regional - 20/62 (6-4-0), 5/62 in OPR
2014 Arkansas Regional - 14/39 (8-7-0, Quarterfinalists with 1706 and 1939), 24/39 in OPR
2013 Lone Star Regional Dean's List Finalist!
2013 Lone Star Regional - 22/57 (6-5-0), 17/57 in OPR
2012 Bayou Regional - 16/49 (6-5-0)
2011 Dallas Regional - 10/52 (4-2-5, #6 Alliance Captain, Quarterfinalists with 2948 and 3350)
Unread 18-02-2014, 09:10
DMike
Posts: n/a
The safety vi was disabled before we started programming autonomous. I'm curious why autonomous doesn't work, but teleop does, when the motors are referenced the same way for both. We are programming using labview and we are using jaguars for the drive system.
Unread 18-02-2014, 09:15
AKA: Joseph Martin
Are there any error messages on the driver station (under the diagnostics tab) or on the netconsole?
Unread 18-02-2014, 09:20
E Dawg E Dawg is offline
... is not done with FRC yet.
AKA: Ethan
FRC #0159 (Alpine Robotics)
E Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud of
Probe your error wires and see what they return.
Unread 18-02-2014, 10:16
Originally Posted by DMike View Post
Any ideas?
We can share plenty of ideas. Since we don't see your code, we can't know whether any of those ideas are good ones. Show us your Autonomous vi and help us help you.
Unread 18-02-2014, 12:35
DMike
Posts: n/a
Here's a photo of the code. We literally enabled one of the stock structures already in the Autonomous code and added a solenoid. The added solenoid code works, the default drive code doesn't.
Unread 18-02-2014, 13:27
Are you actually using a Mecanum drivebase?
Is your drive motor reference in Begin named "Four Motors"?
Unread 18-02-2014, 14:01
DMike
Posts: n/a
yes and yes. The motors will turn as programmed sometimes but it's really inconsistent. They will usually only turn once every time we load the code to the cRio, and generally it does not work the first time we enable the code. We don't have the code actually burned to the cRio yet so could that have something to do with it?
