Go to Post If no hint or advanced BOM don't come out, will it make you not participate in FIRST this year?? - Elgin Clock [more]
Unread 18-02-2014, 09:00
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Gearbox Question
Decreasing the diameter will increase the force applied to what the winch is pulling. But it will also increase the time it takes to move it.
Unread 14-03-2014, 12:18
golucky66 golucky66 is offline
FRC #4055
golucky66 is an unknown quantity at this point
Team 4055 had a problem with tensioning our catapult. I don't know exactly what is a problem with yours but we had a few issues.
1) We had one CIM tensioning the catapult
2) There was a large amount of friction because we didn't use bearings (Bad decision)
3) We were applying force to our arm at an extremely small angle.
Fix
1) We designed a completely bolt on mechanism. It was a 4.5 to 1 ratio with two CIMs.
2) We upgraded to a 1/2 in keyed shaft with Oil Impregnated Bronze Bearing
http://www.amazon.com/Spyraflo-PB1-5...bronze+bearing
3)Force has it's maximum efficiency when the force is applying perpendicular to the arm. Relocating our attachment point for our winding strap helped.
