Go to Post When you are able to get inside their heads, you will either... or.. B) Learn way to much, and end up running away screaming. - Either way, it'll be a learning experience. - Elgin Clock [more]
Unread 18-02-2014, 09:14
apm4242 apm4242 is offline
FRC #4242
apm4242 has a brilliant futureapm4242 has a brilliant futureapm4242 has a brilliant futureapm4242 has a brilliant futureapm4242 has a brilliant futureapm4242 has a brilliant futureapm4242 has a brilliant futureapm4242 has a brilliant futureapm4242 has a brilliant futureapm4242 has a brilliant futureapm4242 has a brilliant future
HELP: 2 Motors 1 Button in LabVIEW
Hi
We are trying to program 2 motors to run in only one direction when a single button is pushed. We have tried a couple of different things with the code but nothing seems to be working. We get no response from either motor.
I have attached pictures of the code we tried. When using buttons 2,3,4, & 5 to run the motors in forward and reverse separately, everything works fine. Any help would be greatly appreciated.
We used the method outlined by Team 358 here:
Unread 18-02-2014, 09:38
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: HELP: 2 Motors 1 Button in LabVIEW
The issue is, you have multiple values going into those motors at one time. If button 4 is not pressed and the trigger is pressed you are feeding both a value of 0 and a value of -1 into x motor at the same instant. You'll need to set the code up so you only have one set for each motor being used at any given time.
Unread 18-02-2014, 09:41
Invictus3593's Avatar
Invictus3593 Invictus3593 is offline
time you like wasting is not wasted
FRC #3593 (Team Invictus)
Invictus3593 is just really niceInvictus3593 is just really niceInvictus3593 is just really niceInvictus3593 is just really nice
In both pictures, you are trying to set each motor to two different values at the same time (having two MotorSet vi's for each motor). This causes the cRio to have to choose between the two values you're sending but it gets indecisive and doesn't cooperate. Condense your code down to only using one MotorSet for both of them and it should work.
Per Audacia Ad Astra
Unread 18-02-2014, 09:56
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
It is good LabVIEW programming practice to absolutely never use more than 1 motor set for a given motor that can execute concurrently. It creates race conditions where you have no idea which one is being set.
As the others have said - get rid of your multiple sets and use one for each motor.
Unread 18-02-2014, 10:23
FRC #4242
Thanks for the replies! That makes perfect sense.
Would it work if we wired button 1 to the green wires for buttons 2 and 4? Essentially having 2 buttons going into a single T/F operator.
I don't have the code in front of me or I would just try it.
Unread 18-02-2014, 10:24
Delete the second pair of Motor Set functions. Use boolean OR functions on the button values to make multiple buttons able to activate the motor. I'm sorry, I don't have LabVIEW handy in order to show you an example.
Unread 18-02-2014, 10:25
Flywheel Police
I like Alan's solution.
Unread 18-02-2014, 10:29
Just move that bottom Select up and add it as a third Select to each of the previous cascades for the x & y motors.
You can add as many Selects as you have buttons.
Name:	Multiple buttons.png
