Go to Post Wait, does this mean TV isn't real? I'm shocked and appalled. - s_forbes [more]
Unread 18-02-2014, 10:16
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Re: R3 20" rule
Originally Posted by N91L View Post
I have a question concerning weaher its just 20" form the side or weather that 20" also counts for the corner... rather than the 28" that would be found using the pothagorian therium...
If I understand correctly, you want to extend into the corner such that, looking downward on a rectangular robot, the furthest point is 20 inches in both the X and Y dimensions from a corner of the robot, leaving it 28" from the corner itself, measured on the diagonal.
Again,
a ROBOT may not extend more than 20 in. beyond the FRAME PERIMETER (see Figure 4-2 for examples)
Figure 4-2 also clearly shows rounded corners for the 20" - you can NOT extend 28" into the corner, only 20" from the nearest point on the frame perimeter.
2016: Lake Superior WFFA
Unread 18-02-2014, 10:27
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: R3 20" rule
How does this figure, taken from the manual, not answer most of the questions in this thread? This rule seemed pretty cut and dry to me.
Unread 18-02-2014, 10:29
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
Re: R3 20" rule
The technique I saw being used for checking this at the LaCrosse WI week 0 event may be helpful.
Hold a plumb bob* so that it touches the furthest reaching (or suspect) point of the extension. If the horizontal distance from the string to the frame perimeter (where the bumpers attach) is > 20" you have a problem.
The plumb bob is also useful to assure that the starting configuration is legal and that everything is inside the frame perimeter
* a free hanging weight attached to a string to produce a vertical line
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
Unread 18-02-2014, 10:31
Joseph Smith's Avatar
Joseph Smith Joseph Smith is offline
Persistence alone is omnipotent.
FRC #3539 (Byting Bulldogs)
Joseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant future
Re: R3 20" rule
It's pretty simple. If you were to draw an outline of your frame perimeter, then you would draw another profile around it offset 20" from your frame. If you had a square frame, the corners of this outer profile would be rounded with a 20" radius. You may fill up this entire outer profile with extensions if you want, but you can't go past it.
For example:
Design/fab team 2011-2013
Design/fab mentor 2014--
There are three types of people in the world:
1. Those who make things happen
2. Those who watch things happen
3. Those who wonder what happened.
Unread 18-02-2014, 12:35
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Re: R3 20" rule
The only issue I have with that image is that it's nowhere near to scale. 20" means you can almost double the short dimension of the kit frame in both directions.
