Go to Post I highly doubt the game has anything to do with water... - rotolomi [more]
Unread 14-02-2014, 19:05
Dave001w Dave001w is offline
Chief Programmer, Chief Driver
FRC #4090 (Reb)
Dave001w is an unknown quantity at this point
How can you make a belt out of tubing?
We have some FreelinWade plastic tubing and would like to belt a belt with it to run it off of a motor.... how would we make a belt out of this that is the perfect size to run between 2 pullies? we are mainly interested in how we would melt the ends together to make a strong enough bond.
We have seen this done before at some competition during Rebound Rumble.
Unread 14-02-2014, 20:05
cmrnpizzo14's Avatar
cmrnpizzo14 cmrnpizzo14 is offline
AKA: Cam Pizzo
FRC #3173 (IgKNIGHTers)
cmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond repute
Re: How can you make a belt out of tubing?
We did this, but with pneumatic tubing. All you have to do is cut it (being a slanted cut instead of square helps so that you can get a larger contact area) then use an electrical heat gun to melt it together into a loop. Works very well and we machined simple pulleys for it.
http://igknighters.com/Robotics/Resources.php
We have video and CAD up on our website of this.
FIRST Team 3173 The IgKNIGHTers
"Where should we put the battery?"
Unread 18-02-2014, 11:02
Cmac3082's Avatar
Cmac3082 Cmac3082 is offline
Electronics and pneumatics captain
AKA: Connor McDonald
FRC #3082 (Chicken bot pie)
Team Role: Electrical
Cmac3082 is an unknown quantity at this point
In 2012 our team used the round frc orange pollycord to make belts. We used a butane torch to get the two ends hit to the point where they melted but a soldering iron with a wood burning tip would work too. When both ends of the cord stared to melt we would slide them together and hold them tightly until they hardened. At the joint the cord would mushroom out making it hard to use but we used a disk sander to sand it down. We made a pulley on a wood lathe and coated it in some unknown epoxy so the cord would not slip. Hope this helps
Unread 18-02-2014, 11:40
AdamHeard's Avatar
Lead Mentor
You really don't want to do this with pneumatic tubing, what you likely saw in 2012 was urethane round belt (polycord).
Mcmaster has it.
Unread 18-02-2014, 11:48
AKA: Cam Pizzo
Mcmaster has it.
I was on the team making them. We had a surplus of pneumatic tubing and began using that to make belts. It worked well and you could get lots of it very cheaply in many different colors.
Unread 18-02-2014, 11:56
AdamHeard's Avatar
Lead Mentor
There is no way it worked well in comparison to polycord. It's not grippy and it's far stiffer.
You'd achiever far, far better performance with polycord.
Unread 18-02-2014, 11:58
Tmaxxrox97's Avatar
Tmaxxrox97 Tmaxxrox97 is offline
FRC #2512 (Duluth East Daredevils)
Tmaxxrox97 is an unknown quantity at this point
We have used polycord to make belts in the past two years and they worked very well for us. What we did to join them together was to take a soldering iron with a large flat tip and melt the two ends of the cord. Once they were molten we slid them off the tip and together until they hardened together. We then sanded off the excess material around the joint.
Hope this helps a little.
If it (the robot) is strong enough to do the task, it should be able to handle any abuse a 16 year old with a joystick can throw at it. --MrBasse
Unread 18-02-2014, 18:20
Chowmaster4695 Chowmaster4695 is offline
Lathe Master
AKA: Jerry Wright
FRC #4695
Team Role: Tactician
Chowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond repute
I think you may be referring to orange polycord. I don't think pneumatic tubing would be good for this. We made the bands by cutting two opposite angle cuts and then holding them together while using a blowtorch to melt the ends. Fast and quick. After the polycord starts changing colors,we then dunk it in a bath of ice and use a grinder to grind of the excess spilled out (we only have a hand one, but bench grinder would work great). We usually make the polycord 30% shorter so we can stretch it nice and tight on the robot.
Unread 18-02-2014, 18:36
cglrcng cglrcng is offline
FRC #0060
cglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond repute
We used the round polycord during Rebound Rumble (thicker & much smaller hole and very stretchy unlike the pnumatic tubing), and used a small alum. 1/2" barbed nipple w/ a center outside diameter equal to the outside diameter of the cord, so it worked perfectly w/out jambing up our pulleys as the joints rotated through), that barbed joining nipple was nearly impossible to push into each end, especially when it was stretched on the pulleys installing in the bot, but very hard to pull back out (usually had to cut those barbed nipples back out w/ a razor knife to re-use them), to join both very straight cut w/ a razor knife ends.
Unread 18-02-2014, 19:01
AKA: Cam Pizzo
I have never used polycord so I can't speak for the direct comparison but 3173 has in fact used pneumatic tubing as belts and been happy with the performance. Originally we saw 2056's robot in 2011 @ FLR (which I believe used polycord) and someone from our team went and talked to them and came back with the (mistaken) conclusion that they were using pneumatic tubing on their claw. We switched our claw to use pneumatic tubing in Boston for our second regional and were very happy with the switch.
In 2012 we used it as belts on our intake and elevation system. Before we really figured out how to make them we suffered from some of them breaking. We perfected the technique by the time we went to St. Louis and had no complaints during CMP.
I'm sure in many instances polycord is better and grippier but for a team that did not have any at the time (and still does not because we have not found a reason to switch) pneumatic tubing was a very successful alternative for us.
Unread 18-02-2014, 20:37
Breadbocks Breadbocks is offline
FRC #1002
Breadbocks is on a distinguished road
How effective are tubing/polycord belts for transmissions? I'm working on an RC car, and was redoing the gearbox and want to replace a pair of gears with a belt, but I was worried it'd slip off at the RPM it spins at.
