Go to Post Don't take my questions negatively, I just hold drive trains to a ridiculous standard. - AdamHeard [more]
Unread 18-02-2014, 12:06
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
Re: Compressor Rule Question
Originally Posted by mathking View Post
I am not sure anything in the rules would prevent one from using a different compressor to charge the robot when you practice with it. Not saying it would be legal, but I would ask the GDC. The compressor itself is a COTS component. So you could completely unhook it, swap it out, and then swap another one back in. That is not what you are asking, but I would ask the question.
Yes, this more or less is what I'm asking (or, at least what I settled on after hearing the rules explanation). "Completely unhooking" is a 2 minute job -- swap the wires, swap the push-in tubing, and remount. Not a bad maintenance task to ensure a cool, healthy compressor in your matches!
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
Unread 18-02-2014, 12:09
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
From the inspection check list:
Compressor - Only one KOP compressor (or equivalent, max 1.05 CFM flow rate) may be used (on or off robot). <R79>.
Does not say one at a time. Does not say 2.
