Re: One Last Pneumatics Question at the 11th Hour
What code platform are you using?
I would try and see if the digital signal is coming out of the pressure switch. Your likely problems are: Pressure switch bad Pressure switch wired incorrectly PWM cable bad PWM cable plugged into DSC the wrong way DSC slot bad I would first see if the control system is reading the digital input and back up from there. |
