Go to Post I'm not the only one confused. Perfect. - MikLast [more]
Unread 18-02-2014, 13:24
Sanchberry Sanchberry is offline
FRC #1466
Sanchberry is an unknown quantity at this point
Re: Compressor Rule Question
What if we use one compressor and fill up the tanks with an on-board compressor in our pit before the match, and use the same Air compressor in matches
Unread 18-02-2014, 13:40
nicholsjj's Avatar
nicholsjj nicholsjj is offline
AKA: John Nichols
no team (Devil Bots)
nicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant future
I think the bigger issue can come in with pneumatics and the battery. If you precharge your system with a "fill" battery wouldn't that violate R34 being that the stored air on your system was from a second battery making you have a two battery power system. If the compressor off board is the exact same as the one on board of the robot wouldn't that be the same as switching the cost compressor between matches. It doesn't give any advantage to the team and in my opinion it is safer due to the system being less heated. I understand that two nonidentical compressors would be against the rules, but isn't swapping out two identical compressors the same as swapping out batteries between filling the system?
2011-FRC Team 3862, Team Captain
2012-FRC Team 3862, Strategy Mentor
2013-FRC Team 3885, Programming Mentor, Razorback Regional, Curie Inspector
2014- FRC Team 3885, Programming Mentor, Arkansas Regional, Newton inspector
2015-??? Teacher Murphysboro High School
“They call it coaching but it is teaching. You do not just tell them…you show them the reasons.”- V. Lombardi
Unread 18-02-2014, 13:44
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
If you are using the same compressor, that is only one compressor?
Q&A Q382 seems to rule against off board air storage.
You can change batteries after charging your air tanks. If you were to ask, the GDC would probably reply that compressors aren't batteries.
Unread 18-02-2014, 13:56
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
And the GDC was asked, and Yes they replied, see Q88.
But no, no comparison was made that batteries aren't compressors</humor></poetry>
