Go to Post Dear CNN, We're not from indiana. Love, Wildstang - AlecMataloni [more]
Unread 18-02-2014, 13:35
goofy173's Avatar
goofy173 goofy173 is offline
Electronics Mentor
FRC #2867 (ElkLogics)
goofy173 is a name known to allgoofy173 is a name known to allgoofy173 is a name known to allgoofy173 is a name known to allgoofy173 is a name known to allgoofy173 is a name known to all
Bent pin in cRIO
Well, the kids bent a pin in our new cRIO. I took it apart to replace it but I found that the pins are pretty stable. Usually just trying to bend a pin back in place breaks it, but I was able to get it bent back, and tested it a few times, and all is well. They already pulled the cRIO out of last years bot and put it in so this will be the spare now.
I realized replacement of the connector was going to be quite a chore; one that I'm capable of, but still it would have been difficult.
So if you find you have a bent pin, you can try straightening it. I used a very small screwdriver, a dental pick, small needle nose pliers, and forceps to get it back in place. It was squashed all the way down so I was quite surprised how robust it is.
