Go to Post Then there's the electronics, pneumatics, and all that stuff on top that will magically make the ball score billions of points. That will add up to a lot of weight. - MrForbes [more]
Unread 18-02-2014, 16:17
Jeffrafa's Avatar
Jeffrafa Jeffrafa is offline
Robotics Addict
AKA: Jeff Lewis
FRC #1425 (Error Code)
Jeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant future
Re: Approved Solenoid?
Just a little background on this valve:
I believe this was in the 2006 KoP, I recognize it from our box of valves. Model # from the 2006 KoP Checklist is 5728400410 (double check that your valve is the same). Mfr info can be found here: http://www.rexrothpneumatics.com/pne...&PageID=p31071
There are grey plastic nuts that slip on the tube before it is pressed onto the barb fittings, then thread onto the casing - without these on all the tube connections you risk having a tube blow-off or get pulled off accidentally. I would be wary of using it without the nuts.
As Joe mentioned, it is up to you to have proof in the form of a spec sheet or other Mfr documentation to show the inspector that the part is legal.
Team 1425 Alumnus and Mentor
I am KF7JDK - What's your callsign?
