Go to Post Sometimes we over react to things, and thats where a PM can clear a bunch of confusion. - mechanicalbrain [more]
Unread 18-02-2014, 15:04
Oblarg Oblarg is offline
AKA: Eli Barnett
Stalling an RS775
Does anyone know if it's possible to keep an RS775 stalled indefinitely without damaging the motor by giving it a sufficiently low voltage, and, if so, how low that voltage is?
Thanks.
"The breakfast of champions!"
Unread 18-02-2014, 16:24
Re: Stalling an RS775
We have not done it with an RS775, however, we have indefinetly stalled fisher price and RS550 motors with outputs of between 10 and 20%. Note that depending on the speed controller you use, that value might have to change.
Unread 18-02-2014, 16:34
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Thanks.
Yes. Our 2011 robot stalled two RS775 motors to hold our arm in position.
Doing math on the torque required showed each motor was only getting 6-7W of power, which is pretty darn safe.
Can't find the internal resistance spec for a 775 off-hand... You could take a multimeter to a 775 and measure the resistance, figure out a voltage that applies less than, say, 10-12W to the motor, and you're off to a good start.
Unread 18-02-2014, 16:41
CRITICALThinker's Avatar
CRITICALThinker CRITICALThinker is offline
New user, first time FRC
FRC #5064 (Opcom Robotics)
Team Role: Electrical
CRITICALThinker is an unknown quantity at this point
There is also the choice of shorting the motor, which is the same procedure the Victor 888's use for braking the drive motors.
Unread 18-02-2014, 16:54
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
All speed controllers, as well as the Spike, use this method. It doesn't hold position and requires the motor to have some speed before having any substantial effect.
Unread 18-02-2014, 17:59
The FRC 2014 motor spec says:
RS-775-18 stall current = 87 amps -> R = 12/87 = 0.138 ohms
RS-775-12 stall current = 30 amps -> R = 12/30 = 0.400 ohms.
So, for 10 watts input power, the RMS voltage at stall would be given by:
V = sqrt(P*R) = sqrt(10*0.138) = 1.17 volts for the 775-18 for 10 watts
V = sqrt(P*R) = sqrt(10*0.400) = 2.0 volts for the 775-12 for 10 watts.
Unread 19-02-2014, 14:33
Fun fact:
the average of 1 volt at 20% duty cycle is 0.2 volt;
the RMS is 0.44; RMS is ~2.23 times the average.
same as above, only 40% duty instead of 20%:
average=0.4; RMS=0.63; RMS is ~1.58 times the average.
same as above, only 60% duty:
average=0.6; RMS=0.77; RMS is ~1.29 times the average.
same as above, only 80% duty:
average=0.8; RMS=0.89; RMS is ~1.12 times the average.
same as above, only 100% duty:
average=1; RMS=1; RMS is equal to the average.
Unread 19-02-2014, 18:45
AKA: Eli Barnett
Thanks very much for all the helpful replies; we'll be running our arm against the hard stop at ~5-10% to keep it in place.
Unread 20-02-2014, 09:20
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Hard to visualize without a picture, but if it's an arm against a hard stop, can't you balance it with springs (surgical tubing) so that stalling the motor(s) won't be necessary? Or use a latch to hold it in place?
Unread 20-02-2014, 09:47
AKA: Eli Barnett
Can't do the surgical tubing, as we'd like it to apply pressure in both of its possible locations, and would like not to do a latch as that requires additional actuators and complexity.
