Go to Post I know you've finished the first 75% of the robot, but do you have enough time left to finish the other 75%? - Rick TYler [more]
Unread 18-02-2014, 20:55
Akolbi Akolbi is offline
FRC #4607
Akolbi will become famous soon enough
A Couple of Questions
Hey! we've got a couple of issues to get rules-legal. Namely, we have no readout on our voltage, and we have a compressor that either will not turn on when we enable the robot, or will not turn off when we disable it.
we have not had our compressor working, yet have the same code as what we had last year. We had help at one point, but still could not figure it out, we have the spike and switch wired correctly....so we have no clue what is wrong.
The battery we USED to get a voltage reading, but it stopped and started reading 00.00 volts. we went to a preregional competition, and since then we noticed the issue. what could have changed in that time?
Unread 18-02-2014, 21:14
Anupam Goli's Avatar
Anupam Goli Anupam Goli is offline
PCH Q&A co-founder/Scouting Mentor
AKA: noops
FRC #1648 (G3 Robotics)
Anupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond repute
Re: A Couple of Questions
For the battery voltage, make sure there is a jumper on the analog breakout board on the pins specified in the control system connectivity guides here: http://www.usfirst.org/roboticsprogr...control-system
EDIT: I think this is on the older analog breakouts. I think the newer analog breakouts don't require the jumper. If there are no pins for you to put a jumper, then the analog breakout board might not be working, and you should look into replacing it.
Team 1002: 2008-2012
Team 1648: 2012-2016
Georgia Tech Class of 2016
Unread 18-02-2014, 21:50
In addition to the jumper, make sure the Analog Breakout is receiving battery power from the Power Distribution Board.
The compressor shouldn't be able to run when the robot is disabled. Do you have it connected to a Spike relay module? Do you have the Spike's control cable connected to a Relay port on the Digital Sidecar?
Unread 18-02-2014, 22:12
DonRotolo's Avatar
Back to humble
FRC #0832
Hopefully you re-created the code from last year? I'm not a programmer, but I was told* that last year's code is not compatible with this year's cRio image.
*By a competent person, BUT I may have misheard, or I may be wrong. I frequently am.
