Go to Post Tell the truth - that's really a small barbecue grill on that robot isn't it. - Tom Line [more]
Unread 18-02-2014, 21:47
whitepokefrost's Avatar
whitepokefrost whitepokefrost is offline
Tan[X] Member
AKA: Adam
FRC #3003 (Tan[X])
whitepokefrost is an unknown quantity at this point
Angry Last minute question
Can a robot possess 2 balls this year? NOT AT THE BEGINNING, throughout the whole match.
Unread 18-02-2014, 21:52
Chris_Ely's Avatar
Chris_Ely Chris_Ely is offline
AKA: luckof13
FRC #3414 (HackBots)
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
Re: Last minute question
There is only one ball in play for each alliance after autonomous, and G12 states that:
An ALLIANCE may not POSSESS their opponent’s BALLS.
So, no you cannot possess multiple balls.
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Unread 18-02-2014, 21:54
Tan[X] Member
AKA: Adam
FRC #3003 (Tan[X])
Unhappy Re: Last minute question
Thank you but no help. During auto if a robot doesn't have a ball at the start of the match the ball is in the middle of the field. if we can hold two balls, can we?
Unread 18-02-2014, 21:58
Chris_Ely's Avatar
AKA: luckof13
Ok, now I understand your question.
I can't find anything in the manual that states you can't, so I would be inclined to say yes. But, I am not the GDC, so you should ask the Q&A.
Unread 18-02-2014, 21:59
Electronica1's Avatar
Electronica1 Electronica1 is offline
Former Design and CAD Captain 1086
AKA: Alexander Kaplan
FRC #0401 (Copperhead Robotics)
Electronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond repute
From what I understand from the rules, you can not start touching more than one ball but once the match has started you can pick up the rest of the balls. Although, you still can't pick up your opponents ball.
I am 75% sure on this but I have not seen anything on the q and a or in the manual about it.
I assume what you are trying to do is pick up your alliance partners balls after auto starts and score those so you do not have to drive back and forth for a multi-ball auto.
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
No. No new balls are released onto the field until all autonomous balls are scored or declared as trapped in the robots.
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 18-02-2014, 22:04
Tan[X] Member
AKA: Adam
FRC #3003 (Tan[X])
Thanks for all the help. besides Whippet who needs to read the rest of the posts.
Unread 18-02-2014, 22:07
Remember this, no matter how cool chief delphi is, it is not official. If I were you, I would double check with the Q and A.
Unread 18-02-2014, 22:15
Chris_Ely's Avatar
AKA: luckof13
If you look at the time on his post, he was probably writing his post while mine was posted.
Unread 18-02-2014, 22:19
Whippet's Avatar
MIT Class of 2020
AKA: Luis Trueba
I apologize, I misread your question. I thought you were implying that balls would be added to the field while another was still in play. In addition, The other posts that I "should have read" were posted while I was typing.
Also,
This is incorrect. Only if the robot starts in the goalie zone can the ball be placed in the center zone, according to G5:
For ROBOTS starting in the white ZONE, the TEAM may preload one (1) of their ALLIANCE’s BALLS such that the BALL is touching their ROBOT.
For ROBOTS starting in their GOALIE ZONE the TEAM may decide if the BALL is: staged between the TRUSS and the ZONE LINE and not contacting an ALLIANCE partner, or removed from the FIELD for the MATCH.
If a ROBOT does not report to a MATCH, its ALLIANCE may decide if the BALL is: staged between the TRUSS and the ZONE LINE and not contacting an ALLIANCE partner, or removed from the FIELD for the MATCH.
Violation: If the situation is not corrected before the start of the MATCH, TECHNICAL FOUL per BALL improperly staged.
You can not just choose to set the ball in the field while your robot is in the white zone. While your robot is there, the ball has to be either touching your robot or out of play.
Unread 18-02-2014, 23:26
G_rupp's Avatar
G_rupp G_rupp is offline
FRC #1108
G_rupp is an unknown quantity at this point
q&a has answered this. q113
