Go to Post All labor is donated by the webmaster "Brandon". - Mike Martus [more]
Unread 18-02-2014, 22:37
NWChen's Avatar
NWChen NWChen is offline
Alum
NWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to behold
Re: Autonomous
Originally Posted by Dinnesy View Post
Your autonomous function should look like
public void autonomous() {
     while(isAutonomous()){  //Place everything in a loop.
        robotDrive.drive(0.5,0.0);//drive at 50% speed 0% turn
        Timer.delay(5.0);//wait 5 seconds
You don't need to iterate in autonomous; assuming you have a sequence of statements (e.g. drive forwards, stop, shoot) they should only execute once each. Look at this example.
Try the following instead:
        robotDrive.setSafetyEnabled(false);
When setSafetyEnabled is true (by default it is), the robot won't drive if the code continues for too long. That's probably causing your robot to stop entirely after ~0.1 seconds.
