Go to Post Just make a FIRST version of Quidditch. The only people who would be complaining are drivers from previous years who wanted to play it. - Koko Ed [more]
Unread 18-02-2014, 23:17
AndyB871 AndyB871 is offline
FRC #0871
AndyB871 has a spectacular aura aboutAndyB871 has a spectacular aura aboutAndyB871 has a spectacular aura about
System Watchdog Errors disabling robot
Hey everyone, We just bagged and tagged a short while ago, but we had one weird problem that we couldn't seem to fix.
We kept getting Watchdog Expiration: System N User 0
Where N increments by 1 every 5 seconds or so.
We're using labview
At first I figured we must have done something dumb in our code accidentally. ( We discovered opening multiple PWMs or Relays twice causes things to go haywire. It would be nice if WPIlib was a little more forgiving of that, but whatever)
I had my guys disabling just about everything in our code with the Diagram Disable Structure. Didn't change a thing, so we rebooted our laptop, started Labview and created a new default robot project, compiled it and deployed it without touching any code at all. Same issue, we get incrementing system watchdog errors, that disables all our outputs for a fraction of a second, every 5 seconds.
That lead us to assume we borked our cRIO setup, so we re-ran the imaging tool and flashed the cRIO again. Same problem with the default code, We get System watchdog errors, and disabling of our output.
Next we figured maybe the hardware was dorked, maybe we had a bad cRIO or a bad sidecar or 9402 or something. To make our isolation easier we flashed last years robot with this years image, and deployed the default program. Same exact behavior. To make sure we didn't accidentally break last years robot, we re-flashed it with last years image, and deployed last years code. Errors went away.
We backed up there and re flashed last years robot with this years crio, and the error came back. At this point we decided to try switching to a different laptop, didn't change a darn thing, still watchdog errors and short output disables.
We also tried to direct connect the cRIO to the laptop to take the switch out of the loop, which also had no effect. Still watchdog errors.
Eventually we gave up and I had my guys work in some error tolerance, so our vision code didn't lose it's marbles when our LED ring clicks off once every 5 seconds.
Our code runs, but man is it annoying for every output to halt every 5 seconds for a half second or so. I've completely run out of ideas as to what we can try.
To sum up where we gave up:
1) Used last years cRIO flashed with this years image
-- Last years cRIO running last years code has no issues
2) Using a freshly generated default robot project from this years code
3) Direct cRIO to laptop connection via crossover
Anyone have any ideas? I'm really concerned that the FMS will end up disabling our robot for the entire match when the system watchdog expires...
Thanks in advance
-Andy & Team 871
Unread 18-02-2014, 23:59
Re: System Watchdog Errors disabling robot
The (good?) news is that FMS won't disable your robot for throwing a watchdog.
The bad news of course is that your robot will be pretty inoperable if your drivetrain keeps getting cut off every 5 seconds.
Do you have a second computer with a fresh install of LabVIEW to try?
I'd re-build default code on a second computer and try running from there to the robot.
That would identify LabVIEW installation corruption. It'd also remove any laptop/LabVIEW issues as a possible source of the trouble.
Unread 19-02-2014, 00:24
FRC #0871
Ah, yeah We didn't try that. I'll wipe labView from our backup laptop, reinstall this years and try to create a clean project. If that works then I guess We'll have to migrate our code into the new project...
I'll let you know what comes of it. Thanks!
Unread 19-02-2014, 03:58
The Charts tab on the DS will tell you quite a bit about what your robot is doing.
It also has a button to launch the Log File Viewer so that you can review previous match and practice data. If the log file view doesn't make sense, post an image of it.
The System Watchdog happens when the robot doesn't receive or process valid info from the driver station for 100ms. It will reenable as soon as it gets valid data.
If you use one of the basic robot templates to compare against, I assume the issue will go away. You can then compare and see that it is code and not something else.
Greg McKaskle
Unread 19-02-2014, 17:17
FRC #0871
That's what we did. First thing We checked was to see if the CPU was pinned, but everything's happy, and we were using the default robot template generated by labview.
Unfortunately we don't have access to the school for the rest of this week so I can't do much more until monday. I'll take a look at the log files, I didn't think to check them out. Would there be some indication of packets being delayed? I didn't see any packet loss or drops....
Edit: Maybe we should try the default robot dashboard. We do have some complicated vision stuff that finds & selects targets from the dashboard then UDP's the selected target over to the robot. On the other hand, we were running with the dashboard off entirely. Something to look at at least.
Unread 19-02-2014, 21:36
If the CPU is not loaded and you are getting system watchdog, that means the packets are not arriving. Please do look at the DB and its CPU usage. The DS is elevated in priority, but with enough overload, I suppose the DS could fail to send packets in time.
The Charts tab will show lost packets per period of time, and it will show the latency of packets that do arrive.
Greg McKaskle
