Go to Post The mediocre do the minimum, then exclaim how easy it is. The exceptional never stop to gloat... they're too busy figuring out new ways to make it even better... - Mr. Lim [more]
Unread 18-02-2014, 20:24
danebouchie danebouchie is offline
FRC #5018
danebouchie is an unknown quantity at this point
Data Range on Joystick.getRawAxis
I couldn't find what the range goes to. Is it mesaured in angles (0-360), radians (0-2pi) or -1 to 1? (Java)
Unread 18-02-2014, 20:36
NWChen's Avatar
NWChen NWChen is offline
Alum
NWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to behold
Re: Data Range on Joystick.getRawAxis
getRawAxis() returns a double in the range -1.0 to 1.0. As a default (joystick centered) the method returns 0.0.
For more information look at the WPILib API courtesy of 2168.
Unread 19-02-2014, 04:36
I'm curious where you found that information in the javadocs. I couldn't find it.
Unread 19-02-2014, 08:58
NWChen's Avatar
Alum
The method summary of getRawAxis() in Joystick links to this source code:
public double getRawAxis(final int axis) {
    return m_ds.getStickAxis(m_port, axis);
getStickAxis() is a method of DriverStation:
private DriverStation m_ds;
and in the DriverStation class the getStickAxis() method used with m_ds earlier is as follows:
public double getStickAxis(int stick, int axis) {
       if (axis < 1 || axis > kJoystickAxes) {
           return 0.0;
           int value;
           switch (stick) {
           default:
               return 0.0;
       double result;
       if (value < 0) {
           result = ((double) value) / 128.0;
       } else {
           result = ((double) value) / 127.0;
       // wpi_assert(result <= 1.0 && result >= -1.0);
       if (result > 1.0) {
           result = 1.0;
       } else if (result < -1.0) {
           result = -1.0;
    return result;
Unread 19-02-2014, 09:03
gluxon's Avatar
gluxon gluxon is offline
\n
AKA: Brandon Cheng
FRC #0178 (The 2nd Law Enforcers)
gluxon has a spectacular aura aboutgluxon has a spectacular aura aboutgluxon has a spectacular aura about
       double result;
       if (value < 0) {
       } else {
Interesting. I wonder if positive joystick values are expanded (more sensitive) than negative ones looking at this code.
Unread 19-02-2014, 09:54
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Not really.
The JS is sent as a signed int (two's compliment) in the UDP packet.
A signed int has a range of -128 to +127. This is because there is no 'negative zero', so there is 1 'extra' count on the negative side since zero is considered a positive number.
Kettering Motorsports
