Go to Post Anything released in a game hint is subject to enough misinterpretation and "nah, they'll never do that" to deflect any possibility of something being actionable. - EricH [more]
Unread 19-02-2014, 00:55
Ikillee Ikillee is offline
FRC #4733
Ikillee is an unknown quantity at this point
Battery orientation
A mentor from our team was not sure if it's legal to have your battery mounted flat. We didn't do this last year and most if not all teams that I've seen have had their battery mounted upright. I don't remember any rule restricting how we can mount our battery. Is it legal to have it flat?
Unread 19-02-2014, 00:56
ehoyla's Avatar
ehoyla ehoyla is offline
FRC #1311 (Kell Robotics)
ehoyla is a splendid one to beholdehoyla is a splendid one to beholdehoyla is a splendid one to beholdehoyla is a splendid one to beholdehoyla is a splendid one to beholdehoyla is a splendid one to beholdehoyla is a splendid one to behold
Re: Battery orientation
We are mounting ours flat. It's perfectly legal.
Unread 19-02-2014, 00:57
FRC #4733
Thanks
Unread 19-02-2014, 07:30
The battery can be used in any orientation. I personally do not recommend charging up side down. As always (do I need to say this?) all exposed metal on the battery and wire terminals needs to be insulated.
Unread 19-02-2014, 09:33
Michael Hill's Avatar
Plus, all the electrons are going to fall out.
Unread 19-02-2014, 10:30
!Alp!
Posts: n/a
From what i know you can mount the battery in any orientation, were mounting ours flat.
Unread 19-02-2014, 11:03
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
We've had ours upright for several years, but it was "flat" in 2010.
Unread 19-02-2014, 11:07
nxtmonkeys's Avatar
nxtmonkeys nxtmonkeys is offline
SCP-682
AKA: Parker Wells
FRC #5349 (RoboEagles)
nxtmonkeys will become famous soon enough
I have seen many different battery mounts, from 3d printed ones (they were in two parts) to ones where the battery is bungee-corded down to the bot. It's best to make sure that the battery is secure and won't come loose during a match. To test how secure your battery is, you may want to drive your robot at the top speed that you might be moving during a match, and turn back and forth. If the battery comes loose, Use a different way to secure it. As for my team, we are using the bungee cords, which works surprisingly well.
Hope you have good luck!
