Go to Post In theory, this should work... Oops. - Eldarion [more]
Unread 17-02-2003, 02:55
duckshepherd's Avatar
duckshepherd duckshepherd is offline
FIRST Veteran
AKA: Jeremy Egger
FRC #0959
duckshepherd is an unknown quantity at this point
Send a message via AIM to duckshepherd Send a message via MSN to duckshepherd Send a message via Yahoo to duckshepherd
Question Solenoid Programming
I'm wondering how the solenoids are supposed to be programmed. For the double solenoid, when you pulse one side, do you keep the solenoid under constant current in order to keep that side of the valve open, or do you only have to momentarily pulse it? And for the single solenoid, does it work like the double solenoid where you simply reverse polarity? And does the current have to be constant and not just a momentary thing to keep the valve open? Any help would be much appreciated.
-Jeremy Egger
Freshman-"Could you hand me that thing that makes that clickety noise when you turn it?"
Senior-"You mean the ratchet?"
No, I refuse. Wait, what? Did you say chicken and cheese? Alright then...
Unread 17-02-2003, 09:15
For a double solenoid, it is best to just pulse 1 side or the other. It is ok, but not the best to hold one side or the other. If neither side get power, it keeps its position. If both sides get power, bad things happen.
The single solenoid needs power to stay extended. if no power is applied, it retracts. You can do some really neat stuff with this, when you realize that it doesn't receive power when the robot is disabled (like after the match), so you can use it to trigger something right as the match ends.
Hope that helps
Programming Compatition Angela06 Programming 30 08-04-2005 23:12
How do you do the autonomous programming? Ryan Collings Programming 11 07-02-2003 19:38
Pneumatics electrical wiring and programming archiver 2001 1 23-06-2002 23:10
Error found in programming for the pump and pressure switch sjharobotics Programming 4 06-02-2002 17:46
pbasic programming punarhero Programming 4 21-01-2002 23:32
