Go to Post I also predict that most predictions will be wrong. - Joe Ross [more]
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Unread 19-02-2014, 13:49
EricDrost's Avatar
EricDrost EricDrost is offline
Eleven to MidKnight
FRC #1923 (The MidKnight Inventors)
EricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond repute
Re: Team 11 - Robot Reveal 2014
Here's a sneak peak of the tread pattern we're using.
Unread 19-02-2014, 14:52
Link07 Link07 is offline
Volunteer
AKA: Andrew
Link07 has a brilliant futureLink07 has a brilliant futureLink07 has a brilliant futureLink07 has a brilliant futureLink07 has a brilliant futureLink07 has a brilliant futureLink07 has a brilliant futureLink07 has a brilliant futureLink07 has a brilliant futureLink07 has a brilliant futureLink07 has a brilliant future
How much extra traction do you get from that as compared to normal colsons?
Unread 19-02-2014, 15:36
Lil' Lavery Lil' Lavery is online now
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
What machining process did you use to cut those? Did you freeze the wheels first? What kind of performance gains have you seen from that? Did you try any other tread patterns?
Unread 19-02-2014, 15:54
LaScooter's Avatar
LaScooter LaScooter is offline
AKA: Wooje Chang
FRC #0011 (Mount Olive Robotics Team)
Team Role: CAD
LaScooter is a glorious beacon of lightLaScooter is a glorious beacon of lightLaScooter is a glorious beacon of lightLaScooter is a glorious beacon of lightLaScooter is a glorious beacon of light
Link07 - We don't have exact numbers, but the traction was much higher than normal colsons. If you are planning on getting into pushing matches, I would recommend them.
Lil' Lavery - We simply took them to a band saw and put cuts in them. Much higher traction gained from simple 5 minutes of work. We are planning on trying out different patterns, but the current design should be significantly better than normal colsons.
Unread 19-02-2014, 16:28
Jscout11's Avatar
Jscout11 Jscout11 is offline
College Student
AKA: Jack
Jscout11 has a reputation beyond reputeJscout11 has a reputation beyond reputeJscout11 has a reputation beyond reputeJscout11 has a reputation beyond reputeJscout11 has a reputation beyond reputeJscout11 has a reputation beyond reputeJscout11 has a reputation beyond reputeJscout11 has a reputation beyond reputeJscout11 has a reputation beyond reputeJscout11 has a reputation beyond reputeJscout11 has a reputation beyond repute
We were able to push Beta around in practice a little bit at least
Member - FRC11: 2011-2014
Unread 19-02-2014, 17:00
EricDrost's Avatar
Eleven to MidKnight
Sean,
I intend to publish a quantitative analysis on wheel tread eventually. But for now we've found that comparatively: straight cut > diamond cut > uncut when it comes to simulated coefficient of friction in the forward direction.
Because the cut is perpendicular to the direction of motion, the forward component receives 100% of the vector's magnitude unlike the angled cuts in the diamond pattern.
The W set of VexPro wheels follow the same logic.
Unread 19-02-2014, 17:21
DonRotolo's Avatar
Back to humble
FRC #0832
Eric, don't forget to consider the traction from when the tread material bends, when the cuts are sufficiently close to each other. A diamond pattern has more cuts and thus some thinner profiles. I can't say if it is significant or not, but rubber car tires use angled siping just so they can get thinner profiles compared to perpendicular siping.
Unread 19-02-2014, 17:32
EricDrost's Avatar
Eleven to MidKnight
I absolutely agree that my explanation was an oversimplification. We intend to do MUCH more comprehensive testing. But with the data points we have so far, the straight cuts are the best performing wheels we've tried.
Unread 20-02-2014, 11:00
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is online now
FRC Video Review - Change is Coming
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
Great looking robot guys. Will surely be a contender in MAR this season!
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
Unread 20-02-2014, 13:33
sportzkrazzy's Avatar
sportzkrazzy sportzkrazzy is offline
AKA: Zac
FRC #1592 (Bionic tigers and 801 Horse power)
sportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant future
Send a message via AIM to sportzkrazzy
Loving the bot this year. Should be a top contender where ever it goes. Looks like the in-house powder coating payed off because she is gorgeous.
