Go to Post There are always rules we don't agree with, just like in life. Our character is defined by how we respond. - Mr MOE [more]
Thread Tools Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
Unread 19-02-2014, 12:55
nxtmonkeys's Avatar
nxtmonkeys nxtmonkeys is offline
SCP-682
AKA: Parker Wells
FRC #5349 (RoboEagles)
nxtmonkeys will become famous soon enough
pic: Another Teleop while loop
Unread 19-02-2014, 14:13
Re: pic: Another Teleop while loop
Are you actually using this code in Teleop? What I see would completely break the robot program if it were placed there.
Unread 19-02-2014, 14:14
nxtmonkeys's Avatar
SCP-682
AKA: Parker Wells
Yes, I am. It works too. I wonder why people keep telling me that there's something wrong? Please tell me if I am missing anything.
Unread 19-02-2014, 14:24
If "stop" isn't true, then putting that while loop in Teleop will keep the rest of the robot program from running. I would expect to see communication issues indicated on the Driver Station.
Since you don't have any sort of delay in the loop, it will also use up all of the CPU time setting the motor output as fast as it can.
Unread 19-02-2014, 14:26
nxtmonkeys's Avatar
SCP-682
AKA: Parker Wells
Huh. It doesn't seem to do that when I run it in parallel with my other loops. I wonder why?
Unread 19-02-2014, 18:00
Pault's Avatar
Pault Pault is offline
FRC #0246 (Overclocked)
Pault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond repute
Telepop itself is in a loop. Adding a while loop inside it is, at the very least, redundant. Although I can see why others think it might cause problems as well.
Unread 19-02-2014, 18:07
nxtmonkeys's Avatar
SCP-682
AKA: Parker Wells
Well, I pretty much have a few while loops which execute at the same time. I have the loops so that I can fire until the battery dies (if I wanted to). I didn't know that teleop was a loop. Huh. Thanks.
Unread 19-02-2014, 22:35
Teleop isn't exactly in a loop. It's called by the Robot Main vi whenever the Driver Station sends new data, and if your Teleop code doesn't finish before the next data packet arrives you'll start tripping the communication watchdog. Putting a neverending loop inside Teleop is a sure way to break your code.
Can you post your Teleop.vi file? I'm curious what you've done that lets the robot work even with the collection of unthrottled and unterminated while loops you say you've put there.
Unread 20-02-2014, 10:48
nxtmonkeys's Avatar
SCP-682
AKA: Parker Wells
Unhappy Re: pic: Another Teleop while loop
Can't right now. my younger brother kneeled on our programming computer and broke the screen, so...
