Go to Post For our next exercise, we should define Beauty and Truth. :) - Taylor [more]
Unread 17-02-2003, 07:58
Re: Re: Using two Large PAPST Fans?
Originally posted by rust710
All Fans hook directly to a 20 amp circuit breaker. The same breaker can be used for all fans. I even put the speed controllers fans on the separate fan breaker. My thought is that if you pop the 40 amp breaker on the motor you should probably still cool the speed controller and you are saving .5 amps that can be sent to the motor.
Not a bad idea! Add a little weight in wire for stable, independent cooling. Cool!
GO Marlins! Tytus Gerrish Chit-Chat 26 17-10-2003 20:44
Fans of Jakie Chan Adventures John JediMaster Chit-Chat 6 14-05-2003 21:12
# of people on team how small or large rcubes85 General Forum 5 18-02-2003 01:35
Sensor use on Papst Large Fan archiver 2001 6 23-06-2002 23:14
Hey Wrestling Fans Out There Mike Schroeder Chit-Chat 9 28-05-2002 09:58
