Go to Post Starting from scratch is what makes it hard. - ChrisH [more]
Unread 19-02-2014, 18:28
Dave McLaughlin's Avatar
Dave McLaughlin Dave McLaughlin is offline
Dave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond repute
Re: pic: Failed pneumatic cylinder
We did the exact same thing. Were you using a stroke limiter around the rod that matched the OD of that bushing?
Unread 19-02-2014, 18:34
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Did they fail under mild circumstances, or under heavy stress?
We made sure we had a hard stop on our shooter to prevent breaking the cylinder, and flow regulators on the collector to slow them down.
Unread 19-02-2014, 18:38
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
A hard stop will prevent the end cap from coming off.
The brass bushing being pushed in usually indicates a bent rod.
Did the Rod take a hit while extended?
___________________
- Tennyson, Ulysses
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
We have a stroke limiter of significantly larger diameter than that of the bushing.
It's not shock loaded too hard, there's a rubber block on each end to prevent it from damaging things like this. We don't want to slow it down, because we want it to be fast.
Kettering Motorsports
Unread 19-02-2014, 19:06
Ours failed under shock load with stroke limiters that were not oversize to avoid only hitting the bushing. We now have much thicker wall on our new stroke limiters. When it happened to our team it was the first time I had seen failure like this.
