Go to Post I don't even consider FIRST to be an extracurricular anymore; it is a way of life. - Jaine Perotti [more]
Unread 19-02-2014, 21:07
yash101 yash101 is offline
AKA: null
Function-in-a-line!!! (C/C++)
Since I have started vision processing, these are nifty functions, that I've consicified into a single line so they are out of the way of your real code!
//string funcs, requiring string and sstream
string bool2str(bool in) { stringstream str; str << in; return str.str(); }
string int2str(int inp) { stringstream str; str << inp; return str.str(); }
string double2str(double in) { stringstream str; str << in; return str.str(); }
//math functions!
double tanDeg(double input) { return tan((input) * pi / 180); }
double hypotenuse(double legA, double legB) { return sqrt(((legA*legA) + (legB*legB))); }
double leg(double hypotenuse, double leg) { return sqrt(((hypotenuse*hypotenuse) - (leg*leg))); }
Give me any feedback and post more of these single-liner c functions!
Unread 19-02-2014, 21:16
Jared Russell's Avatar
Taking a year (mostly) off
Re: Function-in-a-line!!! (C/C++)
There is a <cmath> function for computing the length of the hypotenuse.
http://www.cplusplus.com/reference/cmath/hypot/
For doing numeric type to string conversions, C++11 supports std::to_string, but without C++11 you could still do your stringstream method with a templated function (since the function body is exactly the same regardless of the argument type).
Unread 19-02-2014, 22:31
SoftwareBug2.0's Avatar
AKA: Eric
FRC #1425 (Error Code Xero)
//math functions!
Use a template:
template<typename T>
string as_string(T const& t){
        stringstream ss;
        ss<<t;
        return ss.str();
Unread 23-02-2014, 19:45
AlexBrinister AlexBrinister is offline
AKA: Alex Brinister
FRC #1768 (RoboChiefs)
AlexBrinister will become famous soon enough
Templates are the best way to go there. C++11 reportedly has a to_string function in namespace std but it is absent from GCC 4.8.2. Kind of irrelevant seeing as WindRiver uses GCC 3.4.4...
Alex Brinister
