Go to Post You are becoming the leaders of tomorrow by leading today. - Chris Fultz [more]
Unread 17-02-2014, 17:45
wilson556 wilson556 is offline
FRC #2389 (oklahoma storm)
wilson556 is an unknown quantity at this point
Unhappy solenoid problems
hello my team is having problems getting some double solenoids to work correctly. when we push the button to make each one work a light comes on, on either side we are not sure if it is programming or if the solenoid is hooked up wrong or just not working. the solenoid is a 24v and is plugged in to the solenoid breakout on the cRIO.
any help would be appreciated.
Unread 17-02-2014, 17:52
Chris_Ely's Avatar
Chris_Ely Chris_Ely is online now
AKA: luckof13
FRC #3414 (HackBots)
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
Re: solenoid problems
Which light comes on? How exactly is the solenoid wired? Is the breakout board wired to 24V? Is there air pressure in the system? Pictures are helpful if you have them.
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Unread 17-02-2014, 17:56
the light on either side of the solenoid comes on when the correct button is pushed.
the solenoid is wired directly to the solenoid breakout and that is wired at 24v
and yes there is air pressure in the system when we test it
sorry i cant post any pictures im not at my school to do that
Unread 17-02-2014, 21:58
starchaser42 starchaser42 is offline
AKA: Nole
FRC #3268 (Viking Robotics)
starchaser42 is an unknown quantity at this point
Are you absolutely sure that the solenoid is fully functional and that your battery is at full charge?
In addition, if you only recently added the solenoid module to your cRIO, have you reimaged it yet?
Unread 17-02-2014, 22:10
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
I'd also check to be sure you have the supply line in the supply valve. Sounds silly but I have seen it more than once.
Unread 17-02-2014, 22:39
RoboMo786's Avatar
RoboMo786 RoboMo786 is offline
Student - Design
AKA: Mo Baig
FRC #3538 (Avondale RoboJackets)
Team Role: CAD
RoboMo786 is an unknown quantity at this point
Please clarify. Are you saying that the light comes on at one end, then goes back to the other end? Is it that you wish to hold the position of the solenoid?
Unread 18-02-2014, 19:07
no, no lights come on until a button is pushed
Unread 18-02-2014, 19:24
mattplotas mattplotas is offline
FRC #1984 (Raider Revolution Robotics)
mattplotas is an unknown quantity at this point
Do you have enough pressure? Solenoids need about 30-40 psi to actuate.
^-_-^
Unread 18-02-2014, 21:35
You say you have a 24v solenoid. From where are you providing power to the Solenoid Breakout?
Unread 19-02-2014, 22:26
yes we do have enough pressure we are using about 60psi
and the solenoid breakout is being powered 20 amp breaker spot on the power distribution board. is this where we need to have it or do we need it to be pluged in somewhere else?
Unread 19-02-2014, 22:28
xXhunter47Xx's Avatar
xXhunter47Xx xXhunter47Xx is offline
Lord of Lazy
AKA: Austin $wagmaster1337
FRC #4738 (Patribots)
xXhunter47Xx will become famous soon enough
The 20 amp breaker spot is 12v.
Unread 19-02-2014, 22:31
ok where do we need to hook it up to? thanks for letting me know.
Unread 19-02-2014, 22:35
Chris_Ely's Avatar
AKA: luckof13
To the same place where the cRIO is wired on the PDB. There is 2 positive and 2 negative 24V terminals.
Unread 19-02-2014, 22:40
Smile Re: solenoid problems
ok i will try that tomorrow with some spare parts thanks for the advise i hope this fixes it
