Go to Post Now the real question is where are corn dogs located on that list? That is truly all that matters. - Thad House [more]
Unread 13-02-2003, 21:09
SuperDave SuperDave is offline
AKA: dave
FRC #0987 (HighRollers)
SuperDave has a spectacular aura aboutSuperDave has a spectacular aura about
Using two Large PAPST Fans?
may a robot use two large PAPST Fans on this year's robot? We would like to use them to cool the robot. We have one from this year's kit and last year's kit. Also, do the fans hook directly up to the circuit breaker? Thanks
Dave R - President (team Leader) Team 987
Las Vegas, NV
Highest Rookie Seed Award (5th seed) - Einstein Division, 2002 Championship
Unread 14-02-2003, 08:54
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
I believe FIRST anwsered this recently. You can use any number of fans for cooling purposes.
Jeff Waegelin
Unread 14-02-2003, 10:50
Super Dave,
Everywhere in the docs where fans are referenced the singular form "fan" is used for the EBM and the multiple "fans" is used for the smaller fans. Although I can find no other reference, I would go with just one fan. Besides the weight is pretty high on that larger fan.
Unread 14-02-2003, 19:18
AKA: dave
Originally posted by Al Skierkiewicz
Super Dave,
what is EBM? thanks
-Dave
Unread 17-02-2003, 07:10
EBM is the new manufacturer name after merger with Papst. EBM is a german company from Mulfingen, GMBH. Their US headquarters are in Farmington, Connecticut.
Unread 17-02-2003, 07:52
rust710's Avatar
rust710 rust710 is offline
#0862 (Lightning Robotics)
rust710 is an unknown quantity at this point
Send a message via AIM to rust710
Re: Using two Large PAPST Fans?
All Fans hook directly to a 20 amp circuit breaker. The same breaker can be used for all fans. I even put the speed controllers fans on the separate fan breaker. My thought is that if you pop the 40 amp breaker on the motor you should probably still cool the speed controller and you are saving .5 amps that can be sent to the motor.
Andrew Radamis
Programmer on 862
info@lightingrobotics.com
Unread 17-02-2003, 07:58
Re: Re: Using two Large PAPST Fans?
Not a bad idea! Add a little weight in wire for stable, independent cooling. Cool!
Unread 17-02-2003, 09:40
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
I am assuming you just always have the fans running but isn't there a rule somewhere that states that you have to hook the fans on the speed controllers upto the inputs of the victor or something like that?
Something about it always being on if there is power going to the unit.
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
Unread 17-02-2003, 09:46
f22flyboy's Avatar
f22flyboy f22flyboy is offline
Distributor of Mayhem
#0540 (Rhythmic Disturbance)
f22flyboy will become famous soon enoughf22flyboy will become famous soon enough
Apparently FIRST has changed its mind again, and now says no
http://jive.ilearning.com/thread.jsp...t=15&trange=15
Godwin Robotics Association- Rhythmic Disturbance
Team 540 Forums
FIRST Look... FIRST Shot... FIRST Kill.
Unread 17-02-2003, 15:11
rust710's Avatar
Your link is bad, but taking the &trange=15 of the end fixes it.
Andrew Radamis
Programmer on 862
GO Marlins! Tytus Gerrish Chit-Chat 26 17-10-2003 20:44
Fans of Jakie Chan Adventures John JediMaster Chit-Chat 6 14-05-2003 21:12
# of people on team how small or large rcubes85 General Forum 5 18-02-2003 01:35
Sensor use on Papst Large Fan archiver 2001 6 23-06-2002 23:14
Hey Wrestling Fans Out There Mike Schroeder Chit-Chat 9 28-05-2002 09:58
