Go to Post What? Thinking is required? I certainly hope not! If so, I'm toast! - Robert Cawthon [more]
Unread 17-02-2003, 10:23
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
Image Discuss: 810 Preview (Digi inputs)
Unread 17-02-2003, 10:27
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
woah someone else is using all the digital inputs
do u have a custom circuit board or is this just the outputs of various sensors?
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
Unread 17-02-2003, 11:17
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
outputs of various sensors. we had too many sensors total, and wound up having to double up and use bits to keep state changes on limit switches wired in parallel . the wiring is crazy this year.
<edit>
oh yeah, CAT 5 cable is godly. 24 awg, it's perfect for running across robot se--err, never mind. i can't say that yet...
</edit>
AIM --> Woloi
Email --> ian@woloschin.com
Unread 17-02-2003, 11:29
i can totaly relate!!!
we ended up using ribbon cable running from screw terminal distrobution blocks to connect all of our sensors to try and keep it atleast somewhat organized and easily modular. Rather then having to unsolder something from the 25pin connector we just have to unscrew a wire.
Unread 18-02-2003, 00:31
DanL DanL is offline
Crusty Mentor
FRC #0097
DanL is just really niceDanL is just really niceDanL is just really niceDanL is just really niceDanL is just really nice
Send a message via AIM to DanL
Yeah, we were origionally thinking about using ribbon cable instead of that cat-5 cable and using 15-pin d-cups designed to snap into ribbon to bring sensor inputs from one side to the other (so that if we wanted to take the robot apart, all we'd have to do is disconnect the d-cups), but we couldn't find any 24awg ribbon that would fit a d-cup, so there went that idea.
Dan L
Team 97 Mentor
Software Engineer, Vecna Technologies
Unread 18-02-2003, 01:44
GhettoTech GhettoTech is offline
#0300 (Ghetto Techs)
GhettoTech is an unknown quantity at this point
Send a message via AIM to GhettoTech
Wow... ALL 16 digital inputs? I'm really currious, what are the 16 different sensors and what are they used for on your robot?
Pretty wires ^_^ Using black for all the ground connections coulda made it a bit easier to deal with overall though ;-) But colorful is good :-D
Unread 18-02-2003, 08:34
College? What?
well, as dan said, we used some CAT-5 cable, because it's easy to handle when it's all together (twisted, sheathed, etc), and then our electrical engineer went "dumpster diving" and found a huge 25-pin cable of 24 awg wire. we took the wires out of that, and used those, since they were all in a bundle, and once again, easier to handle. and yes, colors and much prettier .
AIM --> Woloi
