Go to Post Weren't you ever told Canada is backwards from the US? - Alex Cormier [more]
Unread 20-02-2014, 18:18
wilful's Avatar
wilful wilful is offline
766 Alum & 4212 Mentor
FRC #4212 (TechnoFerrets)
wilful will become famous soon enough
pic: Grasshopper Drive
Unread 20-02-2014, 18:49
TheMadCADer TheMadCADer is offline
TheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant future
Re: pic: Grasshopper Drive
I've seen a few drivetrains like this, notably in 2011 when 33 and 1477 each used some type of it (and just so happened to form an alliance at Championships that year). I'm sure there are more out there, plus you can also look at Butterfly drive designs since the principle is fairly similar.
For info on 33's version, check out their white paper as well as their CAD and code. It's hard to notice in their build video, but it's there if you look.
For 1477, I don't think there is much more available than what I could see in their build video (but there are plenty of shots of it in there). James Tonthat would be the person to ask for more information on it.
Unread 20-02-2014, 18:50
xXhunter47Xx's Avatar
xXhunter47Xx xXhunter47Xx is offline
Lord of Lazy
AKA: Austin $wagmaster1337
FRC #4738 (Patribots)
xXhunter47Xx will become famous soon enough
I've actually been thinking about this but with a WCD that deploys omni/mecanum wheels and detracts the drive wheels to allow strafing.
I think the free rolling of the center wheels caused it to be bad, have you thought about incorporating it with motors?
Unread 20-02-2014, 19:29
wilful's Avatar
I know for a fact that is what cause the 2012 robot to be bad, which is why I spent my time making this, where all of the wheels are driven
Wilful
2009-2013 Student, FRC 766
2013-Present College Student and Mentor, FRC 4212
Unread 20-02-2014, 19:31
Chris is me's Avatar
AKA: Pinecone
I would be very worried about side loading on the modules. With modules that long, you run significant risk of deflection under load and thus throwing chains, damaging parts, etc.
Parallel plate drivetrains can be a good choice if you have the right combination of resources (or rather, lack thereof), but just know that you end up using a lot of material in the axis you don't need it. Your strength is going to come from your standoffs. If you have any way to add flanges (e.g. making this out of C-Channel) it will add to rigidity substantially. This is especially important on the drop down wheel.
I would significantly reinforce the drop module and shorten the moment arm (try having a pair of sprockets idle on a shaft close to the wheel, that lets you shorten the module without breaking center distances). If you can add some mechanism to transmit side loads through the chassis (i.e. delrin guides physically constraining the module), all the better.
The integrated piston support is rather cool, but not a super efficient use of resources. You end up using more than twice as much material that just ends up being wasted.
Unread 20-02-2014, 19:37
Electronica1's Avatar
Electronica1 Electronica1 is offline
Former Design and CAD Captain 1086
AKA: Alexander Kaplan
FRC #0401 (Copperhead Robotics)
Electronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond repute
I am going to leave this here.
Also, from the cad, it looks like you could take an AM14U and adapt it to this design by adding the lever arm and also adding a piston mount. It would save you time and money over constructing your own sheet metal frame.
Unread 20-02-2014, 20:00
wasayanwer97's Avatar
wasayanwer97 wasayanwer97 is offline
Take from the best, invent the rest
AKA: Wasay Anwer
FRC #0668 (The Apes of Wrath)
wasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant future
Looks nice, although I'm not convinced of the practicality.
(Not to discredit the design. Practicality is subject to resources anyways.)
I spent a lot of time this year practicing plate drives myself, and nothing like his ever occurred to me.
A few questions/concerns though:
First, (though pardon me if I missed something, I'm only learning too) I can't really see the advantage of this over a normal, drop center, 6 wheel. It seems like there may be a lot of complexity and use of resources that might not provide an equal return in performance. What is achieved by going from 6 to 4?
Second, you might to want to lighten those plates, as there's a lot of unneeded material in that plane. Structure optimally comes from profile, not thickness. And in this case, as previously mentioned, it's going to be the standoffs that provide most of your support.
Also, already mentioned before too, but having separate plates that you bolt/rivet on for your piston support would save a lot of metal.
Looks cool altogether though. I'd love to see where this goes.
"Coming together is a beginning; keeping together is progress; working together is success."- Henry Ford
FRC Team 668: The Apes of Wrath
Pioneer High School, San Jose CA
http://www.theapesofwrath.org
Talking to other FIRSTers is great. Add me on Facebook!
My Page
Unread 20-02-2014, 20:12
AKA: Pinecone
The huge advantage is that you lose the ability to spin / be spun. This has big consequences in certain games - for example, it's a lot harder to beat an unprotected full court shooter that you can't spin. Breaking through defense in certain scenarios is also easier, since a lot of defense is targeted high speed ramming designed to spin. This is one of the subtle advantages of a butterfly style drivetrain.
Unread 20-02-2014, 20:27
AKA: Wasay Anwer
Ah. I see now.
I had noticed that before, but I didn't stop to think of the positive advantages to it. That's a pretty good way to minimize the effectiveness of defense.
Good to know. Thanks Chris!
One more reason to add to my list as to why we'll try a butterfly over the off-season...
My Page
Unread 21-02-2014, 09:32
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is online now
45 Alumni
AKA: Peyton Yeung
45's 2011 robot had the front 2 wheels on a pivot similar to a jaw. When the cylinders were actuated the front 2 wheels lowered raising our center wheels. It saw limited use during competition but it helped with auton. It also helped when we t-boned robots while on d because we couldn't rotate well so they couldn't spin out of the way.
461 Westside Boiler Invasion
45 Technokats
