Go to Post Just because you can doesn't mean you should. - pfreivald [more]
Unread 20-02-2014, 15:21
nxtmonkeys's Avatar
nxtmonkeys nxtmonkeys is offline
SCP-682
AKA: Parker Wells
FRC #5349 (RoboEagles)
nxtmonkeys will become famous soon enough
pic: 3d printed 1/2 inch hex shaft to arm part
Unread 20-02-2014, 15:24
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Re: pic: 3d printed 1/2 inch hex shaft to arm part
Be careful when you put torque on it.
Depending on the type of printer you have the plastic may split around the hex.
Do you have sharp corners around the points of the hex?
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 20-02-2014, 15:25
nxtmonkeys's Avatar
SCP-682
AKA: Parker Wells
What do you mean by sharp corners?
Unread 20-02-2014, 16:07
Botwoon's Avatar
Botwoon Botwoon is offline
A.K.A. Matthew Ruane
FRC #0207 (Metalcrafters)
Botwoon will become famous soon enough
Any corner that isn't radiused.
Unread 20-02-2014, 16:18
nxtmonkeys's Avatar
SCP-682
AKA: Parker Wells
On the part, I'm not sure. I will soon post an image from INVENTOR PRO.
Unread 20-02-2014, 18:46
Joe195's Avatar
Joe195 Joe195 is offline
Mechanical Designer
FRC #0195 (Cyber Knights)
Team Role: CAD
Joe195 has a spectacular aura aboutJoe195 has a spectacular aura aboutJoe195 has a spectacular aura about
I would definitely round the base of the hex extrusion to add some strength. Besides that, looks great!
2014 New England District Championship 1st Seed, Finalist With 558 and 5122, and Industrial Design Award Winner
2014 Southington District Event 1st Seed, Quality Award Winner, and Champions With 558 and 999
2014 Groton District Event 1st Seed and Industrial Design Award Winners
2013 IRI 8th Seed
2013 WIWI Winners
2013 Beantown Blitz Winners
2013 BattleCry Winners
2013 Connecticut Regional Winner
2012 Connecticut Regional Winner
2011 Connecticut Regional Winner
2011 WPI Winner
2007 Connecticut Regional Winner
2006 Newton Division Champions & Einstein Finalists
The Website http://www.team195.com/
Unread 20-02-2014, 19:34
Chris is me's Avatar
AKA: Pinecone
This is a great example of a part that didn't need to be 3D printed. A wide variety of off the shelf hubs combined with a simple plate gusset would do the job much better, with far less risk of failure. Optionally you could broach your own part from solid, but most teams don't have a hex broach.
The hub around the hex should probably be thicker if you keep this plastic.
Unread 20-02-2014, 19:53
nxtmonkeys's Avatar
SCP-682
AKA: Parker Wells
Yeah, I did do both of those things on a later model, but I don't have the file on my computer for some reason. IDKY.
