Go to Post FIRST is like pizza--you and I might prefer different toppings, but there's no wrong way to do it. - Billfred [more]
Unread 20-02-2014, 19:24
CRITICALThinker's Avatar
CRITICALThinker CRITICALThinker is offline
New user, first time FRC
FRC #5064 (Opcom Robotics)
Team Role: Electrical
CRITICALThinker is an unknown quantity at this point
Wiring Maxbotix ultrasonic sensor to serial on cRIO?
My team is planning to add a ultrasonic sensor at the pits (MB 1013 http://www.maxbotix.com/Ultrasonic_Sensors/MB1013.htm ) to our bot using the serial port on the cRIO to aim our launcher.
What is the best way to wire it (even through another port), and how would we go about coding it? Thanks all for the help to a very inexperienced team
Unread 20-02-2014, 19:34
BitTwiddler's Avatar
BitTwiddler BitTwiddler is offline
electronics/programming mentor
AKA: Mr Tanguay
FRC #1726 (N.E.R.D.S.)
BitTwiddler is on a distinguished road
Re: Wiring Maxbotix ultrasonic sensor to serial on cRIO?
Are you programming in LabView?
If so go to the opening splash screen, select Support, Find FRC Examples, go down to sensors folder and open it, find EZ-1 MB1010 Sonar - Analog.lvproj. and start it. The example shows how its done.
Whoops, I just re-read your post where you say you plan to use the serial port. Sorry, that's gonna be trickier.
Unread 20-02-2014, 19:48
we are also programming in C++
Unread 20-02-2014, 19:55
RoboMo786's Avatar
RoboMo786 RoboMo786 is offline
Student - Design
AKA: Mo Baig
FRC #3538 (Avondale RoboJackets)
Team Role: CAD
RoboMo786 is an unknown quantity at this point
Look at the attached pics. One will show you what to wire to the rangefinder. The other pic is from team 358 website. It shows you the Analog Input Module (NI 9201) and the Analog Breakout. You should plug the pwm cable from the ultrasonic rangefinder to any of ports 1-7 on the analog breakout.
My team is programming in LabVIEW, so I can't help you with code, sorry.
Hope this helps.
Name:	EZ-1 ultrasonic wiring.PNG
ID:	16347  Click image for larger version
Unread 20-02-2014, 19:57
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
We are doing the same thing. The serial port on the Maxbotix sensor (at least our model) is not real RS-232. It is an inverted TTL serial port. We had to make a circuit to invert the signals then pass it through a TTL-RS232 converter to get it to work.
Good luck!
Unread 20-02-2014, 20:01
AKA: Mr Tanguay
you could run the TTL signals to and from the DIO ports but then you'd need a driver to extract out the serial data. Not sure if there's a library API that does that.
Unread 20-02-2014, 20:11
mega900997's Avatar
mega900997 mega900997 is offline
FRC #0263 (Sachem Aftershock)
mega900997 is on a distinguished road
We are using the same sensor on our robot. I wired it so it would give an Analog voltage(white wire on a PWM to pin 3) and plugged it into the analog module on the cRIO. In the code, I did:
AnalogChannel *UltrasonicSensor;
UltrasonicSensor = new AnalogChannel(1);
float Distance = UltrasonicSensor->GetVoltage();
I don't remember the conversion from voltage to feet offhand but that can be figured out with a bit of testing.
Heres the datasheet for the sensor. Read the pin out section of the sensor and wire accordingly. http://www.maxbotix.com/documents/HR..._Datasheet.pdf
Suffield Shakedown Winners & Most Points Scored
South Florida Regional 6th Seed, #5 Alliance Captains, Regional Winners w/ 2383 & 386, Innovation in Control Award
NY Tech Valley Regional 5th Seed, QF, Excellence in Engineering Award
SBPLI Long Island Regional 4th Seed, Finalists
Hopper Division 14th Seed, QF
