| View Poll Results: Can your team use this? | |||
| Yes of course I am going to grab our math guy right now! |
0 | 0% |
| Not really. Just not for us, man. :/ |
0 | 0% |
| Voters: 0. You may not vote on this poll | |||
#16
STEMpunk’s shooter, optimized with applied mathematics: Ever wonder what the single greatest, most spectacular, ABSOLUTE BEST angle and velocity to shoot your game piece at is? Well, for us, it’s 36 degrees at 31.62 feet per second. (From ~43.3in above the ground. Giving us a 13.5 ft thick strip of the playing field to make the shot on.) ![]() If you want to optimize your robot like we did ours, for 2014 or any other year involving a goal and a projectile, I would encourage you to read on and find out how got these numbers.A week into the build season our robot was well past the first basic stages of design. Our team, having decided on the layout of our drivetrain (utilizing an unusual application of the mechanum drive) and our shooter, (a virtually one piece rig functioning as an all in one, passing, shooting, ground/ air pickup mechanism) needed to know now, what results our shooter should produce to classify as a “good shooter”. The algorithms we contrived to give us this definition, if utilized properly, should afford most teams with the capability to find that one combination of angle and velocity giving them the single greatest, most spectacular, ABSOLUTE BEST strip of the playing field to make the shot from. You can find our results above. This is how we did it: (See "MathProofCondensed.docx" attachment.) No doubt you will want someone who enjoys rigorous mathematics suiting these calculations to your own robot, but it’s worth the work, as this not only draws a bold line between a "bad shooter" and a "good shooter", but also marks the difference between a "good shooter" and a "perfect shooter". Last edited by Symph : 19-02-2014 at 23:04. |
#17
Awh, thanks man! Q^Q You are a real bro, you know that?
#18
Re: Best launch angle and velocity: HANDS DOWN..
According to the model we are using there is a strange occurrence:
From a height of 3.5' And an angle of 35 deg. And a ball speed of 35 fps There is a pretty decent window. Not quite perfect, but it would have been a good design point to start at. |
#20
Is it a simple parabolic model (like Gabe is using)? Or does it include air drag?
For a simple parabolic trajectory with those launch parameters, the max height of the top of the ball is 10.8 feet*, which exceeds the top of the goal. * assuming you meant that the 3.5' launch height was the top of the ball, rather than the center Last edited by Ether : 20-02-2014 at 17:17. Reason: added plot |
#21
Great work on the kinematics, though the pedant in me objects to absolute terms like "best" and "ideal". There are a variety of factors at play driving the shot of a ball.
Now, for extra credit, using reasonable assumptions for energy transfer, figure out how much spring potential energy your team's system needs to make this shot. ![]() One thing I didn't see, but I'm too busy to compute - for what range of distances is the ball able to go in the goal? |
#22
The model we are using includes air drag (but not spin).
#23
Ether, 3.5' was the bottom of the ball.
#24
Some follow-up questions, if I may?
- are you using a linear or quadratic air drag model? - how did you validate the model? i.e. How did you determine the proper value for the drag coefficient for this year's game piece? |
#25
I put together a few observations about parabolic trajectories in a short 2-page paper here. I'll be adding more as time permits. Last edited by Ether : 21-02-2014 at 02:07. |
#27
- are you using a linear or quadratic air drag model? - how did you validate the model? i.e. How did you determine the proper value for the drag coefficient for this year's game piece? I used a terminal velocity of 36fps, which someone on here had obtained. To double check it I translated it to a Cd of .58, which given the calculated Reynolds number, corresponded to a NASA page relating drag on a sphere to Cd. Once I had Cd, I used .01sec intervals starting from the launch position, Calculate Vx, Vy, and Drag Force, I use Drag force and gravity to adjust the numbers for the new angle of motion and Velocity, and repeat to trace the arc. Here is my Spread Sheet. See the sheets for 'Flight Calc' and 'Flight Path' to get all the details. (You can check out the other sheets too if the interest you) |
#28
All the plots below are based on the parameters in your spreadsheet (launch speed = 35 ft/sec, launch angle = 35 deg, g = 32.2 ft/sec2, terminal velocity = 36 ft/sec, ball weight =3 lbf etc): Plot1 shows your results compared to the true* flight path. Trapezoidal integration is easy to do in Excel for problems of this type. I can write a short paper explaining how to do it if anyone is interested. *mathematically "true" based on the model used. I computed the true flight path using second-order Runge-Kutta at 0.01 time step. With RK2, smaller time steps are not necessary for this application as they yield virtually identical results: See PlotRK Last edited by Ether : 22-02-2014 at 14:57. |
#29
By the way, switching gears for a moment from math to real-world engineering, here's a comparison between the parabolic trajectory and the air_drag trajectory, assuming terminal velocity of game piece is 36 ft/sec and air drag is proportional to the square of velocity. Does anyone else have test data they'd be willing to share, that could be used to confirm the air drag? Last edited by Ether : 23-02-2014 at 12:17. |
#30
I found the calculations for sphere terminal velocity here:
http://hyperphysics.phy-astr.gsu.edu/hbase/airfri2.html it seems to mesh with the previous numbers we used for Vterm. Ether, I'm still digesting the plots, and learning about the methods. I'll have more to say once I learn more. |
