Thread Tools |
Rating:
Display Modes |
Re: Team 1339 Reveal
It is not a pneumatic punch.
The wheels used for pickup are thrown into reverse and the piston just moves the ball into contact with the wheels. |
Are the secondary banebot wheels behind the shooter wheels passive? It seems like they're there to keep the ball in.
Plus, that intro made me smile. Last edited by bEdhEd : 20-02-2014 at 20:59. |
That is partially correct while it does help keep the ball in it also makes sure the ball is centered when picked up.
Ironic Dead Bird is correct. It is essentially a wheeled shooter, ala a pitching machine. The front wheels are both the intake and the shooter. The wheels behind them are unpowered dead axle, and are simply the holding mechanism (they hold very firmly; we tried to punch and kick the ball out and couldn't move it out). The pneumatics are for pushing the ball into the wheels.
Other notable features: -3Cim Ball Shifters with 5.1:1 and 15.5:1 in an East Coast wheelbase -sweet 1 1/4" x 4" Colsons, crown-flattened and with a lightweight hub straight from BaneBots. I will add pics of these later; they deserve a spotlight! -220 degree arm rotation, picks up and shoots from the front or the rear -nice 'n easy piston-only ground or kiss pass Ask if you've got any other questions! |
I like this design a lot - a very elegant way to do a double sided pickup/shooter. See you guys in Utah and Denver!
The Robot looks Awsome! Great Job!
We actually have a similar design and were wondering what you are using to power the wheels from the Cims. Is it V-belt, timing belt, chain? We tried using V-belt but are having a lot of problems with the Cim not being able to get past the friction in the V-belt and pulley. Do you have any suggestions? Also what type of metal are your shooter arms made of? Is that just box aluminum? Thanks so much! And Good Luck! |
#8
I like the shot of you punching a ball out of another robot, though they had the same color bumpers which is probably bad. I wonder how the referees will call something like this, it will be hard to tell if a team actually just hit the ball or if it hits part of the opponent robot inside their frame perimeter.
#9
The belts pass through the arms, which are 1/16" tubing. We chose the thin material for its weight on the moment arm, but it's been a lucky choice in that it will break without damaging any other arm or robot parts (learned by experience). We can bring extra arms and change them out with a pretty quick turnaround time. |
#10
Just want to make sure it's super clear that nobody on our team thought the foul was cool; we laughed at the video because we remembered how embarrassing it was when we drove into the other bot. I thought the kids handled it well afterward, but like I said, it was tense. No one wants to be the team that damages another team's bot, and that one could have ended badly. 3200 were great sports, BTW, kudos to them.
#11
We've been very fortunate to have several students willing to take on videography this year. http://youtu.be/I-Q1fHMzZEg |
#13
Awesome looking bot 1339! Our team is looking forward to playing with you guys in Utah in a few weeks
#14
Expect a follow up on suggestions. |
