Go to Post I would like to think that I would be considered smart no matter who I was. - Kelly [more]
Unread 08-02-2014, 09:59
tuXguy15's Avatar
tuXguy15 tuXguy15 is offline
Team Mentor
AKA: Devin Kolarac
FRC #2559 (Normality Zero)
tuXguy15 is an unknown quantity at this point
Exclamation Maxbotix Range Finder
How do you wire the am-2435 to the robot and the cRIO?
http://www.andymark.com/product-p/am-2435.htm
Unread 08-02-2014, 11:54
geomapguy's Avatar
geomapguy geomapguy is offline
Centenary '18
AKA: Graham Maxwell
FRC #1818
geomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud of
Re: Maxbotix Range Finder
Wire the ground, 5V, and analog signal to the analog breakout to receive voltage that translates to distance. 2.54 V = 254 cm
The Cowboys - FIRST Robotics Team #1818 2015-
The Bolton Bear Bots - FIRST Robotics Team #3666 2011-204 (30-26-0)
2014 Oklahoma Regional - 20/62 (6-4-0), 5/62 in OPR
2014 Arkansas Regional - 14/39 (8-7-0, Quarterfinalists with 1706 and 1939), 24/39 in OPR
2013 Lone Star Regional Dean's List Finalist!
2013 Lone Star Regional - 22/57 (6-5-0), 17/57 in OPR
2012 Bayou Regional - 16/49 (6-5-0)
2011 Dallas Regional - 10/52 (4-2-5, #6 Alliance Captain, Quarterfinalists with 2948 and 3350)
Unread 08-02-2014, 12:12
TogetherSword8 TogetherSword8 is offline
FRC #0888 (Robotiators)
TogetherSword8 is an unknown quantity at this point
You can also wire it using the DIO port on the Digital Sidecar and measure the signal coming in. There are Labview examples for both methods (analog and digital) if you use that as your coding program.
I program a robot. Which means I write code and everyone gets mad at me when something doesn't work, even if I am the only one that knows it doesn't work. The key part to know is that the robot never works.
Unread 08-02-2014, 12:42
cglrcng cglrcng is offline
FRC #0060
cglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond repute
Here is the link for the Maxbotix Range Finder White Paper/datasheet;
http://maxbotix.com/documents/XL-Max..._Datasheet.pdf
Unread 18-02-2014, 10:13
discobrisco's Avatar
discobrisco discobrisco is offline
FTC #2410
discobrisco is an unknown quantity at this point
Is anybody using this currently? We are using it and having problems picking up what we can only assume right now is the carpet and giving us extremely low values quite often. I'd be curious to see how anybody else is mounting this, and if anybody else is having this problem. We are running it off the analog output right now, and today are going to print a mount which will hopefully "focus" the cone more.
Unread 18-02-2014, 10:15
geomapguy's Avatar
Centenary '18
AKA: Graham Maxwell
FRC #1818
We're using it. We are mounting about 20 in above the ground. We bent some polycarb and made a little mount
Unread 18-02-2014, 14:38
RandeJ RandeJ is offline
AKA: Rande Johnson
FRC #4931 (Edwardsville Tech)
RandeJ is an unknown quantity at this point
We are using ours in analog mode and it's mounted about 30" above the ground. It was working really well until mid-day yesterday and now it's flatlined at about 3ft. We'll troubleshoot tonight. Other than that, only issue was slow response (due to 2 Hz filter) in analog mode. But for what we're doing, that was good enough.
Also found this little gem to help with mounting at Allied Elec: Item # 70196662, P/N BF-010175. It's a small black box with mounting tabs that holds the sensor perfectly.
Unread 18-02-2014, 15:23
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
We've used these before and they are very sensitive (they pick up leaves, small leaves). I'd recommend checking for any debri on the floor and also checking to ensure you haven't fried the sensor.
Unread 20-02-2014, 19:58
FTC #2410
Update: with the printed cone mount as high on our robot as possible we're having no trouble with it, we did go ahead and take the largest value every 1/5th of a second to smooth outputs as well which really helped.
