Go to Post However, as a philosopher, while you need math, you can probably talk your way out of it. - sciguy125 [more]
Unread 20-02-2014, 21:09
ehfeinberg's Avatar
ehfeinberg ehfeinberg is offline
AKA: Evan
FRC #0449 (Blair Robot Project)
ehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant future
Post FRC 449 The Blair Robot Project Reveal Video
This is our first time ever doing one of these fancy reveal videos, hope you enjoy it.
Introducing our 2014 robot, Ballbasaur!
http://www.youtube.com/watch?v=ohBv7...=youtube_gdata
Robot Specs:
  • 95% accurate from the front of the low goal. The robot rams right into the low goal to line up.
  • Strong and fast drive train
  • Quick ball intake which doubles as a ball holder in the up position.
  • Large catcher which makes it easy to catch a ball from other robots or the human player.
Mechanical Specs:
  • Drive: 6 wheel west coast drive utilizing WCProducts 3 CIM single speed gearboxes and 4x1.5 inch colson wheels. We are also using belts along with the new WCProducts bearing blocks. The entire drive is geared for 14 feet per second.
  • Intake: Uses 4 bane bots wheels driven with a 1:1 gear ratio from a BAG motor with a 25:1 gear reduction. Pneumatically actuated out. It was specially designed so it holds the ball firmly in place when the roller is in the up position.
  • Shooter: Pneumatic shooter using 2 1.5 inch diameter by 8 inch stroke cylinders. Can shoot only from the front of the low goal and over the truss.
  • Catcher: 3 state catcher which is able to both funnel and disperse the energy of the ball. The shooting state has the front out and the sides in, the drive state has all sides in, and the catching state has the front in and the sides out. When the ball comes and hits the back of the catcher, it pushes the back out moving the sides in both trapping the ball and eliminating the balls energy. The top of the catcher is 59" and it extends out 16" or so on each side.
  • Superstructure: All made out of 2x1x.125" aluminum with custom made gusset plates to connect all the corners. All of this was made with a miter saw and a band saw, there were no CNC'd parts on the entire robot.
Gotta catch 'em balls!!
“They’ve done studies, you know. 60 percent of the time, it works every time.” — Brian Fantana
"You miss 100% of the shots you don't take." - Wayne Gretzky
"Simplicity is the ultimate form of sophistication" - Leonardo da Vinci
Unread 20-02-2014, 21:11
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
Re: FRC 449 The Blair Robot Project Reveal Video
Wow thats one of the best catchers ive seen so far.
1592(Student and Mentor) 2007-2012
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
Unread 20-02-2014, 21:13
jwallace15's Avatar
jwallace15 jwallace15 is offline
What am I going to do with my life?
AKA: Wally
FRC #0068 (Truck Town Thunder)
jwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud of
I really like it!
J Wallace IV
Truck Town Thunder
Just a college student now.
