Go to Post the political parties should consist of AndyMarkcrats and IFI-icans.... - Josh Hambright [more]
Unread 17-02-2003, 10:48
powercat powercat is offline
powercat is an unknown quantity at this point
turn on the light - question
Greetings,
Our rotating beacon is currently on whenever the robot has power. Should
I set it to only power on when comp_mode is 1. That way its off, until the start of the competition ?
just want to do it right.
thanks.
Unread 17-02-2003, 11:07
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
Re: turn on the light - question
You need to hook up your light to a spike relay connected to one of the relay outputs on the robot controller. In your program, all you need to do is be sure that that relay is on all the time. The robot controller will take care of turning it off when your robot is disabled.
Unread 17-02-2003, 11:30
Right now, I have it on a relay that is on all the time. (when power is applied to
the robot). Other than that, I need to do nothing else with the light ? Sorry but I want to get it right.
Unread 17-02-2003, 11:45
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
That is correct. Whenever the robot is in "disabled" mode, all relays and PWMs will be set to 0 or 127, respectively, regardless of what your code is telling them to do. This is to insure that it is impossible to drive before or after the match.
Unread 17-02-2003, 12:57
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
Are you saying that you already had your light hooked up as Rob and I described, and you still observed the behavior you described in your original post? Or are you just expressing incredulity that my advice was correct?
Take a look at the Robot Electrical Blueprint. Near the lower left corner it shows how your light and its relay need to be connected electrically. (It omits the ground wire from the relay back to the distribution panel. If you need help with that let us know.) You'll note that the light is isolated from the rest of the electrical system by the relay. (That is, the light wires are not connected to the same terminals as any other wires.)
If your light is connected as shown, then you have a bad spike relay.
Unread 17-02-2003, 13:05
Sorry, not trying to offend anyone.
I have the rotating light connected to
relay8.
relay8_fwd = 1
set that in the code.
when power is applied to the robot, the
red light starts rotating immediately. I
have not tried the disable button on our competition port dongle to see if the light stops when it is pressed.
Am going to have to check real quick.
Unread 17-02-2003, 14:00
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
No offense taken. Just trying to understand.
Unread 20-02-2003, 09:33
TangoBravo1318 TangoBravo1318 is offline
#1199 (Aesthetics)
TangoBravo1318 is an unknown quantity at this point
Send a message via AIM to TangoBravo1318
Greetings,
thanks.
ok. thats correct, all you have to do is put a section of code in that looks like this:
'===========Turn on rotating light ====================
relay8_fwd=1
relay8_rev=1
Depending on your electricians, your light will turn on either on FWD or REV. Change one to 0 and if it dosent turn on, change the other to 0 and that one to 1. Also, the OI takes care of the light, and other "stuff". That has the same effect as "disabled" (unplugging your OI)
- Curtis
Unread 20-02-2003, 10:49
Lord Nerdlinger Lord Nerdlinger is offline
Lord Nerdlinger has a little shameless behaviour in the past
what's wrong with just plugging it into one of the 20amp fuses and grounding it?
Unread 20-02-2003, 12:43
#1199 (Aesthetics)
The light is only supposed to be on when the robot is enabled. Basically, you dont want the robot to be flashing in the pits. The best way (and, to my knowledge ,the ONLY way) is the way i described earlier.
- Curtis
Unread 20-02-2003, 22:08
Jared Russell's Avatar
Taking a year (mostly) off
The best part?
relay8_fwd = 1 -- light turns clockwise
relay8_rev = 0
relay8_fwd = 0 -- light turns counterclockwise
relay8_rev = 1
Unread 21-02-2003, 22:53
JLambert's Avatar
JLambert JLambert is offline
#0151 (Wild Cards)
JLambert is an unknown quantity at this point
Send a message via ICQ to JLambert Send a message via AIM to JLambert Send a message via Yahoo to JLambert
Originally posted by Abwehr
The best part?
relay8_rev = 0
relay8_rev = 1
The lead programmer on our team used this as a little extra 2 years ago. He made some auto-balancing code, and when the robot was balanced on the bridge, the light reversed directions.
It had no real purpose, but it was nifty to see.
Justin Lambert
02-03: Programmer Team #151
Unread 22-02-2003, 17:33
Greg McCoy's Avatar
Greg McCoy Greg McCoy is offline
boiler up!
FRC #3940 (CyberTooth)
Greg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond repute
Send a message via AIM to Greg McCoy
I can imagine the excitement
Please...no more steenkin' light! Andrew General Forum 37 17-04-2003 23:06
compressor and light question... archiver 2001 5 24-06-2002 00:47
Important info about light Jay Lundy Technical Discussion 10 12-04-2002 11:37
How many posters does it take to change a lightbulb? Brandon Martus Chit-Chat 7 22-02-2002 19:48
A quick question Joelster Technical Discussion 6 10-02-2002 09:09
