Go to Post They know how to make paperweights into other objects, like robot controllers. - Greg McKaskle [more]
Unread 19-02-2014, 14:33
adlasa's Avatar
adlasa adlasa is offline
President and Lead Programmer
AKA: Sasha
FRC #1458 (Red Ties)
adlasa has a spectacular aura aboutadlasa has a spectacular aura aboutadlasa has a spectacular aura about
Morse Code
Hello guys. I wrote a Morse Code class which takes a solenoid which powers our camera light, and a text to convert to Morse. It runs on a parallel thread and allows the camera to flash some fun and interesting messages.
Hope you like it,
Sasha
public class MorseCode implements Runnable{
	//To Call: (new Thread(new MorseCode("Hello World", caneraLight)).start();
	public static String sentance;
	public static String code[];
	public static Solenoid cameraLight;
	public static boolean isDone;
	public MorseCode(String inputSentance, Solenoid light){
		code = new String[inputSentance.length()];
		sentance = inputSentance;
		cameraLight = light;
		convertToMorse();
		isDone = false;
	public void run(){
		cameraLight.set(false);
		try {
			Thread.sleep(4200);
		} catch (InterruptedException e) {
			// TODO Auto-generated catch block
			e.printStackTrace();
		for(int i = 0; i < code.length; i++){
			for(int j = 0; j < code[i].length(); j++){
				if(code[i].charAt(j) == '*'){
					cameraLight.set(true);
					try {
						Thread.sleep(600);
				}else if(code[i].charAt(j) == '-'){
					try {
						Thread.sleep(1800);
				}else if(code[i].charAt(j) == ' '){
					try {
						Thread.sleep(600);
			try {
				Thread.sleep(1800);
		isDone = true;
	private void convertToMorse(){
		for(int i = 0; i < sentance.length(); i++){
			if(sentance.charAt(i)=='A' || sentance.charAt(i)=='a')
				code[i] = "* -";
			else if(sentance.charAt(i)=='B' || sentance.charAt(i)=='b')
				code[i] = "- * * *";
			else if(sentance.charAt(i)=='C' || sentance.charAt(i)=='c')
				code[i] = "- * - *";
			else if(sentance.charAt(i)=='D' || sentance.charAt(i)=='d')
				code[i] = "- * *";
			else if(sentance.charAt(i)=='E' || sentance.charAt(i)=='e')
				code[i] = "*";
			else if(sentance.charAt(i)=='F' || sentance.charAt(i)=='f')
				code[i] = "* * - *";
			else if(sentance.charAt(i)=='G' || sentance.charAt(i)=='g')
				code[i] = "- - *";
			else if(sentance.charAt(i)=='H' || sentance.charAt(i)=='h')
				code[i] = "* * * *";
			else if(sentance.charAt(i)=='I' || sentance.charAt(i)=='i')
				code[i] = "* *";
			else if(sentance.charAt(i)=='J' || sentance.charAt(i)=='j')
				code[i] = "* - - -";
			else if(sentance.charAt(i)=='K' || sentance.charAt(i)=='k')
				code[i] = "- * -";
			else if(sentance.charAt(i)=='L' || sentance.charAt(i)=='l')
				code[i] = "* - * *";
			else if(sentance.charAt(i)=='M' || sentance.charAt(i)=='m')
				code[i] = "- -";
			else if(sentance.charAt(i)=='N' || sentance.charAt(i)=='n')
				code[i] = "- *";
			else if(sentance.charAt(i)=='O' || sentance.charAt(i)=='o')
				code[i] = "- - -";
			else if(sentance.charAt(i)=='P' || sentance.charAt(i)=='p')
				code[i] = "* - - *";
			else if(sentance.charAt(i)=='Q' || sentance.charAt(i)=='q')
				code[i] = "- - * -";
			else if(sentance.charAt(i)=='R' || sentance.charAt(i)=='r')
				code[i] = "* - *";
			else if(sentance.charAt(i)=='S' || sentance.charAt(i)=='s')
				code[i] = "* * *";
			else if(sentance.charAt(i)=='T' || sentance.charAt(i)=='t')
				code[i] = "-";
			else if(sentance.charAt(i)=='U' || sentance.charAt(i)=='u')
				code[i] = "* * -";
			else if(sentance.charAt(i)=='V' || sentance.charAt(i)=='v')
				code[i] = "* * * -";
			else if(sentance.charAt(i)=='W' || sentance.charAt(i)=='w')
				code[i] = "* - -";
			else if(sentance.charAt(i)=='X' || sentance.charAt(i)=='x')
				code[i] = "- * * -";
			else if(sentance.charAt(i)=='Y' || sentance.charAt(i)=='y')
				code[i] = "- * - -";
			else if(sentance.charAt(i)=='Z' || sentance.charAt(i)=='z')
				code[i] = "- - * *";
			else if(sentance.charAt(i)=='0')
				code[i] = "- - - - -";
			else if(sentance.charAt(i)=='1')
				code[i] = "* - - - -";
			else if(sentance.charAt(i)=='2')
				code[i] = "* * - - -";
			else if(sentance.charAt(i)=='3')
				code[i] = "* * * - -";
			else if(sentance.charAt(i)=='4')
				code[i] = "* * * * -";
			else if(sentance.charAt(i)=='5')
				code[i] = "* * * * *";
			else if(sentance.charAt(i)=='6')
				code[i] = "- * * * *";
			else if(sentance.charAt(i)=='7')
				code[i] = "- - * * *";
			else if(sentance.charAt(i)=='8')
				code[i] = "- - - * *";
			else if(sentance.charAt(i)=='9')
				code[i] = "- - - - *";
			else
				code[i] = " ";
Computers run on smoke. When the smoke escapes the computers stop working.
Unread 19-02-2014, 14:42
nxtmonkeys's Avatar
nxtmonkeys nxtmonkeys is offline
SCP-682
AKA: Parker Wells
FRC #5349 (RoboEagles)
nxtmonkeys will become famous soon enough
Re: Morse Code
Veeeery eeeeenteresting.
No, really, That's cool. Was it hard to do?
Last edited by nxtmonkeys : 19-02-2014 at 14:43. Reason: Cuz it sounded VERY sarcastic
Unread 19-02-2014, 14:53
adlasa's Avatar
AKA: Sasha
Re: Morse Code
No not really. This was my first time using Java threading but it turns out its fairly easy to use.
The time consuming part was typing the Morse code database.
Unread 19-02-2014, 17:33
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Morse Code
Talk about the ultimate status display. So long as your drivers know Code, they can get quite a lot of data off the robot.
(Yes, I know there are other ways, too)
Unread 20-02-2014, 00:13
ekapalka's Avatar
ekapalka ekapalka is offline
FRC #3216
ekapalka has a spectacular aura aboutekapalka has a spectacular aura about
Re: Morse Code
Is using threads in Java as "risky" as it is in C++? By that I'm referencing this incident. I sort-of caught some heat from one of our mentors for attempting to show our new programmers how to use threads because there's a lot of potential unintended coordination issues (even if the threads are basically acting as their own separate programme, like this one appears to be). Thanks, and this project seems really cool :)
Unread 20-02-2014, 22:15
heuristics heuristics is offline
FRC #3634
heuristics is on a distinguished road
Re: Morse Code
Threading is only "risky" if you don't properly synchronize the data you're sharing across the threads, and only if synchronization matters for the specific task. I wouldn't say either language is necessarily more difficult to synchronize. In both, you need to think through your critical sections, make sure you're locking mutexes, semaphores, etc. in the appropriate places.
Unread 21-02-2014, 08:44
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Re: Morse Code
Don't show your code to your English teacher. You could be "sentanced" to remedial spelling assignments.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 21-02-2014, 11:03
nickmcski nickmcski is offline
AKA: Nicholas McCurry
FRC #1482 (Grandin Ghosts)
nickmcski has a spectacular aura aboutnickmcski has a spectacular aura aboutnickmcski has a spectacular aura about
Is there a reason you used else if instead of a switch statement?
Unread 21-02-2014, 15:25
SousVide SousVide is offline
SousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to beholdSousVide is a splendid one to behold
Re: Morse Code
Great Job on the thread code.
Unread 22-02-2014, 10:04
taichichuan's Avatar
taichichuan taichichuan is offline
Software Mentor
AKA: Mike Anderson
FRC #0116 (Epsilon Delta)
taichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud of
Send a message via AIM to taichichuan
Re: Morse Code
Don't be afraid of threads. They are a very basic mechanism in any real-time or embedded code development. I know Dave Wilner personally and was involved in the periphery of the Pathfinder problem.
The confusion came as a result of something called the priority inversion problem that is common in real-time systems. In VxWorks, there are 3 different kinds of semaphores that are used for different purposes. The one that's used in the "CRITICAL_REGION/END_REGION" code is the mutual exclusion semaphore that caused the problems for Pathfinder. The problem with Pathfinder was that that semaphore was not created with the SEM_INVERSION_SAFE flag set. However, the constructor used in WPILib automatically set that flag, so you should be good.
Just make sure you protect any global variable accesses in the CRITICAL_REGION/END_REGION wrappers and everything should work fine.
Good Luck,
Mike
