Go to Post Our opponents didn't know where our robot was going and neither did we! - ReapersRule [more]
Unread 16-02-2003, 15:55
RAWdealer59 RAWdealer59 is offline
#0059 (RamTech)
RAWdealer59 is an unknown quantity at this point
Toggle between in and out (Pneumatics)
How can we program the pneumatics to toggle between in and out? Right now we can only leave the piston out by holding the button down. How can we set it up to toggle?
Thanks
Unread 16-02-2003, 16:38
are you using a single or double solenoid. What type of switch are you using (spst, dpdt, momentary, locking, etc). That's the bare minimum information, because each combination would have a different line (or lines) of code to work.
Unread 16-02-2003, 17:03
tonyargote's Avatar
tonyargote tonyargote is offline
#0059 (RamTech 59)
tonyargote is an unknown quantity at this point
Send a message via AIM to tonyargote Send a message via Yahoo to tonyargote
i believe we are using a double solenoid
TArgote
Driver, Programmer, Webmaster
www.RamTech59.com
UCF: Ranked 13th (2nd Highest QP's in the Nation! (349))
Championship: Ranked 12 out of 73 teams in Archimedes Division, Quater finalist allied with 1108 (GO 1108!) & 868 ( GO 868!)
Unread 16-02-2003, 22:30
Coach C's Avatar
Coach C Coach C is offline
#0341 (Miss Daisy)
Coach C is an unknown quantity at this point
You probably have something like this:
relayX_fwd = pX_sw_trig
You need something like this:
if (pX_sw_trig) then relayX_fwd = 1
if (pX_sw_top) then relayX_fwd = 0
If using two buttons is out of the question, you'll have to get a bit more creative:
if ((pX_sw_trig ~= LastState) & (pX_sw_trig = 1)) then
relayX_fwd = OpenClose
OpenClose = OpenClose - 1
endif
LastState = pX_sw_trig
Unread 16-02-2003, 22:59
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
endif
The PBASIC operator for not equal is <>. Also, use the keyword AND instead of &. Finally, can get rid of the variable OpenClose and just use relayX_fwd=1-relayX_fwd if you are running low on variable space. Either way, make sure to set relayX_rev=1-relayX_fwd.
Unread 17-02-2003, 00:15
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
umm... im using &, and ~= and their working just fine in my code...
and they are used in the default code from I.F.
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Unread 17-02-2003, 01:47
~= is not valid syntax. The editor complains about it and won't even tokenize. It also is not any of the four default codes, so I'm not sure where you saw it. As for &, it is not the correct operator to use here. Here's a quote straight from the Stamp Manual (page 153):
The easiest way to avoid the kinds of problems this might cause is to always use a conditional operator with IF...THEN. Change the example above to read IF Flag = 1 THEN IsTrue. The result of the comparison will follow IF...THEN rules. Also, the logical operators will work as they should; IF NOT Flag = 1 THEN IsTrue will correctly evaluate to false when Flag contains 1.
This also means that you should only use the "named" conditional logic operators NOT, AND, OR, and XOR with IF...THEN. The conditional logic operators format their results correctly for IF...THEN instructions. The other logical operators, represented by symbols ~ & | and ^ do not; they are binary logic operators.
Finally, see any of the below threads for more info:
http://www.chiefdelphi.com/forums/sh...threadid=18007
http://www.chiefdelphi.com/forums/sh...hlight=bitwise
Unread 17-02-2003, 11:32
The big guy
yea my bad on the first one.. that one doesent work*bops self in head*
Justin Stiltner
KI4URQ
