Go to Post I'll try to sum up the icon and compile thing quickly so as not to interrupt the design of SkyNet. - Greg McKaskle [more]
Unread 20-02-2014, 18:25
William Kunkel William Kunkel is offline
Programming Lead
AKA: Kunkel
FRC #0422 (Mech Tech Dragons)
William Kunkel is an unknown quantity at this point
Consistent robot flicker every 64 seconds
We noticed a really odd problem with the robot when we started doing full testing. Every 64 seconds, the robot "flickers" for a fraction of a second. Relays (and possibly PWMs) shift into neutral, as well as solenoid valves. There is an audible clicking from the solenoid valves and almost every light on the robot goes out. However, we don't lose communications, and everything is back to normal a split second later. Still, the behavior is very disconcerting, and we can't see any obvious explanation for it. Before I get into trying to flowchart the code to see if anything is illuminated, is anyone aware of any sort of loops in WPILib that run on a 64-second timer?
Unread 20-02-2014, 18:35
Re: Consistent robot flicker every 64 seconds
Does anything show up in the DS log when this happens?
Have you substituted a different computer as the Driver Station in case it's a Windows task popping up every 64 seconds (which I have seen before)?
Unread 20-02-2014, 18:56
Programming Lead
AKA: Kunkel
There's nothing on the DS. And we tried deploying just the simple robot template provided by Wind River, which removed the problem, so I think we can rule out the computer (probably).
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
We've had something similar happen, although it seems much less consistent (ie. could be 10 or 50 seconds). I've put it up to lag, although I've had a sneaking suspicion that it isn't. (how could it be even?)
All opinions are my own.
Unread 20-02-2014, 21:07
Deetman Deetman is offline
AKA: Kevin Dieterle
Deetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond reputeDeetman has a reputation beyond repute
I spent a considerable amount of time troubleshooting with a team at their build site where they were disconnecting over WiFi every 6 seconds, no matter what code was on the robot. Ended up being something with the driver station laptop and swapping it fixed the issue.
Can you post your driver station log file and a screenshot of it? It really is one of the most important pieces to tracking down issues. If you don't know how to get to it, go to the "Charts" tab on the driver station interface and then click the "Launch viewer" button in the bottom right.
FIRST Mid-Atlantic Volunteer (2012-present)
Team 1014 Alumni (2004-2005)
Team 1712 Mentor (2011-2015)
Unread 20-02-2014, 21:33
Jared Russell's Avatar
Taking a year (mostly) off
What language are you using?
Could be garbage collection.
Unread 20-02-2014, 21:37
geomapguy's Avatar
geomapguy geomapguy is offline
Centenary '18
AKA: Graham Maxwell
FRC #1818
geomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud of
I think C++
Wind River
The Cowboys - FIRST Robotics Team #1818 2015-
The Bolton Bear Bots - FIRST Robotics Team #3666 2011-204 (30-26-0)
2014 Oklahoma Regional - 20/62 (6-4-0), 5/62 in OPR
2014 Arkansas Regional - 14/39 (8-7-0, Quarterfinalists with 1706 and 1939), 24/39 in OPR
2013 Lone Star Regional Dean's List Finalist!
2013 Lone Star Regional - 22/57 (6-5-0), 17/57 in OPR
2012 Bayou Regional - 16/49 (6-5-0)
2011 Dallas Regional - 10/52 (4-2-5, #6 Alliance Captain, Quarterfinalists with 2948 and 3350)
Unread 20-02-2014, 22:08
k4mc k4mc is offline
AKA: Kushal
FRC #0955 (CV Robotics)
k4mc is an unknown quantity at this point
Perhaps you have a memory leak that is causing the processor on the cRIO to reset every 64 seconds? That would explain why you don't loose communication but everything else resets and could be likely given C++ doesn't have a garbage collector.
You could at least easily test if this is the issue by downloading sample code onto the bot and waiting 64 seconds.
Edit: I just noticed you said that sample code removes the problem, so I now highly suspect something in your code is periodically crashing. If its not a memory leak, you could try first uploading an empty file and slowly adding one class/file/functionality at a time to see which part is causing the crash.
Unread 20-02-2014, 22:32
Do you happen to have a 16-bit unsigned int that is counting milliseconds?
Unread 21-02-2014, 07:08
If the flicker is short, this isn't caused by a crash or reboot. I agree with Jared that something in the code is probably overflowing.
Greg McKaskle
Unread 21-02-2014, 09:30
E Dawg E Dawg is offline
... is not done with FRC yet.
AKA: Ethan
FRC #0159 (Alpine Robotics)
E Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud of
I concur with the above. Go through your code and make sure that there are no overflow warnings (hopefully WindRiver alerts you to that).
Unread 21-02-2014, 10:26
MamaSpoldi's Avatar
MamaSpoldi MamaSpoldi is offline
Programming Mentor
AKA: Laura Spoldi
FRC #0230 (Gaelhawks)
MamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant future
Check the NetConsole output. There could be helpful messages being printed there that could point you in the right direction.
Unread 21-02-2014, 10:53
Programming Lead
AKA: Kunkel
Sorry for not responding quickly. We're using C++, and I'm compiling with -Wall -pedantic -Wextra and not getting any warnings or errors. I agree that it's probably an overflow error of some sort, but 64 seconds seemed like such a specific number that I was hoping it might be something in WPILib. There is no output over netconsole. Looking at the DS Log Viewer, there seem to be spikes in dropped packets that correspond to the flickering.
Unread 21-02-2014, 11:05
PandaHatMan's Avatar
PandaHatMan PandaHatMan is offline
AKA: Wallpe
FRC #1747 (Harrison Boiler Robotics)
PandaHatMan is an unknown quantity at this point
Where is your D-Link on your robot? Is it close to any noisy circuits?
Unread 21-02-2014, 11:16
Programming Lead
AKA: Kunkel
Our D-link is pretty isolated. I don't think it's the problem.
