Go to Post The only thing happy about ship day is the promise of sleep coming soon... - StephLee [more]
Unread 11-02-2014, 18:49
mbshark's Avatar
mbshark mbshark is offline
AKA: Myles Byrne
FRC #3932 (The Dirty Mechanics)
mbshark is an unknown quantity at this point
Making a Custom Dashboard For Java
I was wondering how (if it's possible) to use a custom dashboard - the one created in Labview which you copy under the C:\Program Files\FRC Dashboard directory and run under default (is any of this wrong?) - while using java. We have some variables in Java (things like ultrasonic sensor output) that we want to use with the default dashboard (because its enhanced UI over the Java SmartDashboard). How can we link these variables to sliders or other UI elements on the default dashboard? Is is as simple as using the putString/putData method or is it more complicated?
Thanks in advance for the help.
Unread 20-02-2014, 21:37
mbshark's Avatar
AKA: Myles Byrne
Question Re: Making a Custom Dashboard For Java
Still wondering how I would be able to do this
Unread 21-02-2014, 01:18
nickmcski nickmcski is offline
AKA: Nicholas McCurry
FRC #1482 (Grandin Ghosts)
nickmcski has a spectacular aura aboutnickmcski has a spectacular aura aboutnickmcski has a spectacular aura about
Try using smart dashboard sfx, it gives you a lot more options on customizing your dashboard http://wpilib.screenstepslive.com/s/...tdashboard-sfx
Unread 21-02-2014, 07:36
Sure! The SmartDashboard calls are language compatible (though note that Test mode is not). In your robot code use SmartDashboard.putBool or putNumber or whatever is appropriate.
Then in LabVIEW create a new Dashboard project from the template and add the indicators or controls to the Operation tab with the same name as the key name you used on the robot. Alternately, put them on whatever tab you like and use the SmartDashboard VIs from the palette to read data and output it to indicators or to write data from controls.
Unread 21-02-2014, 08:03
fovea1959's Avatar
fovea1959 fovea1959 is offline
Herder of programmers
AKA: Doug Wegscheid
FRC #3620 (The Average Joes)
fovea1959 will become famous soon enough
Ruffles: how is test mode not compatible?
Unread 21-02-2014, 12:07
They use different NetworkTables naming. There's no reason that someone couldn't make a LabVIEW dashboard control a Java/C++ robot in test mode, just that the default LabVIEW dashboard won't (and vice versa).
Unread 22-02-2014, 17:56
fovea1959's Avatar
AKA: Doug Wegscheid
Joe: thanks. didn't understand it was a cross-language incompatibility....
