Re: Mechanum drive-strafing issue
So a 2:3 reduction off of a CIMple box is a 7:1 total reduction, which is not enough. With 6 inch wheels, you need somewhere between a 10:1 and 12:1 reduction to have enough torque to strafe. You can get this with either a larger reduction coming off the CIMple box, or replace the CIMple box with a toughbox.
Thanks for the help on this.
By the way, how much would adding additional CIMS to each transmission help? (I know that only 6 are allowed, for post-competition purposes) |
Have you ensured that your wheel rollers form an "X" when viewed from above, or an "O" when viewed from below?
This will not affect the ability to strafe. If the programming assumes worm's eye view "O", but mechanically it is "X", then strafing will be opposite of the commanded direction. It would make rotation difficult,if not impossible, however.
Thank you for the help. I have arranged the mecanum wheels in the "X" fashion to allow it to move freely. The weight distribution is also fairly even, and the robot is slightly underweight. The wheels also have a lot of friction to them, and some of the rollers were locked up when I found them. (vise grips time)
I appreciate all of the math stuff. I attempted to show the difficulties of it at the beginning of the year, but I had little luck. I think the primary problem here is that there isn't a high enough mechanical advantage. Since my last response, the team has decided to use ToughBox transmissions that we found in the shop. I looked at the gear ratios, and that should be the solution to the problem. |
If the rollers in contact with the floor form the X, you have a problem. With that arrangement, the robot can be turned easily by an outside force, and it will have a difficult time turning itself. Quote:
#7
http://www.youtube.com/watch?v=1mrNH0Czq0I The other reason the rollers may be tight is if the aluminum spiders are "pinching" the rollers. We removed the pinched roller and used large pliers or channel-locks to bend the fingers for that roller apart slightly. Hope this helps. |
#8
2013 used mechanum back in breakaway and that was the last time they used that system due to the limitations and problems they had. If I remember correctly, they were running about 16:1 reduction off CIM motors with 8" custom built wheels. http://www.youtube.com/watch?v=bxw4sGeKakE
Ever since though: ![]() |
#9
When you say "can't strafe" does that mean it struggles to move very fast or literally no movement? If the latter, have you tried giving it a push to get it started? Is your acceleration in the forward/backward direction normal?
You might double check that your rollers spin freely. When I spin our (3 year old) AM mecanum wheel rollers, they spin for several seconds before friction stops them, or they are cleaned, adjusted or swapped. Quote:
Deciding on a gear ratio for your drivetrain is deciding how to distribute power between speed and torque. If you change the ratio, one goes up, and another goes down. You can't just pick any top speed you want, however. Your wheel translates torque to a linear force and pushes the floor, and Newton says the floor pushes back the same amount. This is the force that accelerates your robot. acceleration tells you how long it will take to get to your top speed. So, if you choose a gear ratio with a crazy high top speed, you won't have the acceleration to get to your top speed within a typical FRC distance. Or, you might not have enough torque to overcome the friction in your gearbox and wheel bearings to move at all... soooooo, if you're still awake... If you keep the gear ratio as is, but add an extra CIM to each gearbox, you are keeping the theoretical top speed the same but basically doubling your torque. It would be legal to add an extra mini-CIM to each gearbox for this year's competition (assuming you haven't used them elsewhere)OK, if you've made it this far, then one other thing to consider is the current draw of your motors at stall. Have you seen JVN's calculator? This will show you speed and current based on your design choices. FYI - the spelling is mecanum. |
