Go to Post When I first read this comic, I thought "Awww, how cute!". But then, thoughts of Karthik singing J. Lo's "Love Don't Cost a Thing" started running around through my head, and everything changed. - Travis Hoffman [more]
Unread 22-02-2014, 00:26
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
pic: VEX Pro Winch 'Dog Gear'
Unread 22-02-2014, 00:28
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
Re: pic: VEX Pro Winch 'Dog Gear'
That's a very... interesting "dog gear."
How much torque is on it? How well has it held up in testing?
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 22-02-2014, 01:23
AdamHeard's Avatar
Lead Mentor
I like it.
I'd wager it can handle a lot of torque.
If you have any issues with it disengaging, replacing the nuts with something more smooth would likely help.
Unread 22-02-2014, 12:04
Orion.DeYoe Orion.DeYoe is offline
FRC #5413 (Stellar Robotics)
Orion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to beholdOrion.DeYoe is a splendid one to behold
Wow, I like it. Very simple design. I see that you have two hubs with bolts and nuts to make them catch. I'm having a hard time seeing how it's released. From the picture it appears that it's released by actuating the gearbox. Is that right? If so, are the winch and the gearbox on completely separate shafts?
Unread 22-02-2014, 12:56
pyroslev's Avatar
pyroslev pyroslev is offline
VirginiaFIRST FTA
AKA: Jack of all trades, Master of few
no team (Forget not 616)
pyroslev is on a distinguished road
Thumbs up Re: pic: VEX Pro Winch 'Dog Gear'
Is that a ratchet wrench I see on the shaft next to the gear box?
And nice move on bolting the seat belt material (which is what I presume it is). Practice robot?
"Complications arose, ensued...were overcome." "I'd trade 500 CNC machines for one good hearted student."
From December to April, since 2002, I forfeit my mental sanity for perfect insanity.
Unread 22-02-2014, 16:54
Ben_R's Avatar
Ben_R Ben_R is offline
AKA: Ben Robson
FRC #1885 (ILITE Robotics)
Ben_R is an unknown quantity at this point
That assembly looks familiar! (Student on the team here)
We have a 100:1 gear ratio coming off the bag motor. We are going to test a 70:1 ratio on the practice bot to increase winching speed but that may not be implemented.
As far as testing goes, we went to a pre-bagging scrimmage last Sunday and practiced for about 3-4 hours. The only mechanical problem we had was that the hub on the motor side became loose due to the set screw loosening.....we put a much larger set screw in. Problem solved.
If you look behind the bag motor and the versa planetary gearbox, you can see a pneumatic cylinder. That is actually what engages and disengages the whole winch assembly.
The motor is mounted to a linear slider. The cylinder is mounted to the motor via the custom brackets and then attaches to the launcher frame on the left. When the cylinder fires, the entire motor assembly with the motor output shaft slides into the engaged/disengaged positions.
The right side of the assembly is a separate shaft from the motor output and is hard mounted.
That is a ratchet! It really helps reduce the winch from turning in the wrong direction once the shooter is cocked.
We are building a practice robot. Rebuilding the launcher from scratch with a few tweaks in mind. The assembly pictured is on the competition bot.
Student Leader of Manufacturing - ILITE Team 1885
