Go to Post Moat confirmed, he was only mostly wrong - swnylm [more]
Unread 22-02-2014, 09:45
taichichuan's Avatar
taichichuan taichichuan is offline
Software Mentor
AKA: Mike Anderson
FRC #0116 (Epsilon Delta)
taichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud of
Send a message via AIM to taichichuan
Re: How do you turn off Analog Ultrasonic Sensors?
If you read the Maxbotix data sheets, you'll find there is a pin that can be used to trigger the ultrasonic on a different ping rate. With this pin being used, you can set the ultrasonics up at different ping rates so they don't interfere with each other nor with other ultrasonics from other bots.
HTH,
Mike
