Go to Post With people from the high northeast, mid east, mid west and far west all in one hotel room, we had the time of our lives simply by sitting there. - Keith Chester [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 14-02-2014, 01:11
Ikillee Ikillee is offline
FRC #4733
Ikillee is an unknown quantity at this point
Second set of motors
Our team has a 2 motor drive train. We have the 2 gearboxes from last year. How easy is it to mount the gearboxes and motors to the wheels? A friend of mine from another team wasn't directly involved with this but he did say it was really easy. Also how significantly does the programming need to adjust? Our chassis is 27"wide by 28" long.
Unread 14-02-2014, 01:16
FRC #4733
Basically what I'm asking is if it's hard to mount a second set of motors to the drive train.
Unread 14-02-2014, 01:22
geomapguy's Avatar
geomapguy geomapguy is offline
Centenary '18
AKA: Graham Maxwell
FRC #1818
geomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud of
Re: Second set of motors
No it's not that hard. Are you guys using the KOP drive system
The Cowboys - FIRST Robotics Team #1818 2015-
The Bolton Bear Bots - FIRST Robotics Team #3666 2011-204 (30-26-0)
2014 Oklahoma Regional - 20/62 (6-4-0), 5/62 in OPR
2014 Arkansas Regional - 14/39 (8-7-0, Quarterfinalists with 1706 and 1939), 24/39 in OPR
2013 Lone Star Regional Dean's List Finalist!
2013 Lone Star Regional - 22/57 (6-5-0), 17/57 in OPR
2012 Bayou Regional - 16/49 (6-5-0)
2011 Dallas Regional - 10/52 (4-2-5, #6 Alliance Captain, Quarterfinalists with 2948 and 3350)
Unread 14-02-2014, 02:11
nicholsjj's Avatar
nicholsjj nicholsjj is offline
AKA: John Nichols
no team (Devil Bots)
nicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant future
It's not that hard at all if your team keeps track of its spare parts. You will need four bolts to mount the motors to the other motor mount port on the gearbox, our team also uses thread locker on them. You will want to attach a CIM shaft output gear with the keyway and retaining clips on the CIM motor before you attach it to the gearbox. Make sure you are using the same tooth count as your other CIM gear that is already mounted. You then will need to add two more motor controllers to your electronics board. You do not have to change programming at all if you are using tank drive. You will however need to change your pwm cable to a Y-pwm cable and plug those outputs into both the already used controller and the newly placed controller. Also pay attention that doing this doesn't add to many CIM motors to your robot total, 6 large CIMs total are the max. This also adds a higher current draw for your drive but it is usually a good choice IMO due to acceleration being increased.
2011-FRC Team 3862, Team Captain
2012-FRC Team 3862, Strategy Mentor
2013-FRC Team 3885, Programming Mentor, Razorback Regional, Curie Inspector
2014- FRC Team 3885, Programming Mentor, Arkansas Regional, Newton inspector
2015-??? Teacher Murphysboro High School
“They call it coaching but it is teaching. You do not just tell them…you show them the reasons.”- V. Lombardi
Unread 14-02-2014, 10:27
FRC #4733
Thanks! We're going to salvage any parts from last year's gearbox. Hopefully we have all of them. If we have time we could assemble them before bag and tag. Otherwise it would have to be at the competition.
Unread 15-02-2014, 00:31
FRC #4733
Are y-pwm cables popular in hardware stores?
Unread 15-02-2014, 01:02
Try hobby stores that deal with R/C vehicles, particularly aircraft, or electronics parts stores--or your kit of parts, which should have had two. Hardware stores probably won't have PWM cables at all.
Unread 22-02-2014, 10:54
GortGortGort's Avatar
GortGortGort GortGortGort is offline
AKA: Lee Cole - Mentor
FRC #5040 (The BoltBots)
GortGortGort has a spectacular aura aboutGortGortGort has a spectacular aura about
Hi , I just posted a photo for you as the gears are in fact different from last year . We infact just ran in to this problem on our bot . You can see the photo .http://www.chiefdelphi.com/media/photos/39698
Hope this helps .
Unread 22-02-2014, 11:28
mrnoble's Avatar
mrnoble mrnoble is offline
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
Both last year's and this year's kitbot gearboxes were designed to work with two CIM motors per box, so you could run a 4-CIM drivetrain. It is irrelevant that they are different from each other. Mounting a second motor to each gearbox only requires that you attach the proper pinion gear (with key), and insert it into the space that's already there for it in the gearbox. Screw the new motor into place, then add two more motor controllers to your wiring and electronics setup.
Unread 22-02-2014, 11:35
mrnoble's Avatar
teacher/coach
Also, adding the new motors at competition (once you've got the relevant parts) will be even easier than at your school/garage, simply because most of the teams there are not only skilled at doing exactly the work needed, but they will be thrilled to help. It is one of the joys of most FIRST teams to help other teams out in the pit area.
Unread 22-02-2014, 14:27
FRC #4733
Thanks for the help everybody. It was really easy to mount. One man job. It's all hooked up and ready to go for our regional in Calgary in April.
