Go to Post I almost forgot the biggest advantage of all! Three times as many people get to hear me and Karthik sing at 2 am! - Derek Bessette [more]
Unread 16-02-2003, 22:58
miketwalker miketwalker is offline
Robot Lifeguard
FRC #1902 (Exploding Bacon)
miketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond repute
Send a message via AIM to miketwalker
What we did was while design worked hard on our design, I got 2 or 3 guys together and made last year's robot do kinda what this years bot will be doing. We then took this and found out flaws in our design, found better, more efficient and faster methods of working as well as gave us the ability to have different codes designed (such as stack tracking) that can be used if we add and setup the sensors. I have a few different little autonomous codes so we can swap codes to counteract what scouting data brings us.
One last thing, with your dead reckoning codes, be careful! I realized very well that over time those numbers WILL change. The drive system is gonna change after running a bit, as things wear in and hardware changes. Also I'd really suggest using the delta_t counter and add it in to your counter since sometimes that RC can be crazy and lose loops like mad. It keeps it so you have your times closer. That's my 2 cents though. Good luck programmers. If you guys got that autonomous running well, great job cause you deserve it.
Chopsaw? Chopsaw.
Unread 16-02-2003, 23:09
CyberWolf_22's Avatar
CyberWolf_22 CyberWolf_22 is offline
Programming and Electrical Mentor
AKA: Allen Gregory
FRC #2587 (Afrobots)
CyberWolf_22 is just really niceCyberWolf_22 is just really niceCyberWolf_22 is just really niceCyberWolf_22 is just really nice
Are code is done we got the auton code working it does perfect 90's everytime not matter about wheel slip or battery it works everytime.
Unread 16-02-2003, 23:11
TOHSlancer TOHSlancer is offline
TOHSlancer is an unknown quantity at this point
could you give me an example of how delta_t would be used? I'm interested in how this could be utilized in my own counter.
Unread 17-02-2003, 00:18
Curtis Williams Curtis Williams is offline
#0588 (Team 588)
Curtis Williams is on a distinguished road
Send a message via ICQ to Curtis Williams Send a message via AIM to Curtis Williams Send a message via MSN to Curtis Williams Send a message via Yahoo to Curtis Williams
Originally posted by rbayer
I've got a program written, but our robot still doesn't drive so I can't test it. I'll be lucky to get 15mins with the robot before we ship...
15 minutes? we should be so lucky.
Unread 17-02-2003, 01:32
Hendrix Hendrix is offline
#0538 (Dragon Slayers)
Hendrix is an unknown quantity at this point
really easy. make sure delta_t is setup in your code like in the default code and use this for your counter...
counter = counter + 1 + delta_t
Unread 17-02-2003, 04:30
JasonStern JasonStern is offline
FRC #1123 (AIM Robotics)
JasonStern is on a distinguished road
Yah, 15 minutes sounds about right. The problem being I have never programed in pbasic before and have no idea if our auto code even works!
***sigh*** what I wouldn't give for fractions and inverse trig functions..........
Unread 17-02-2003, 09:19
I've talked to several teams, and none of them got line following working with just 3 sensors. One used 5 sensors and has it working, and the rest of us are using dead reckoning.
edit: do a search on delta_t. I know I've explained it several times, and I know others have as well.
Unread 17-02-2003, 11:47
Hey, errrm there's a robot emulator out there. go to the innovation first website. It's a good way to test if your code is messed up or not. Can't really predict turning and stuff because that's all based on your robot, but it helps.
Oh really? Nobody got their working on 3 sensors? Ours works decently. I just did some testing on carpeting last night.
We just had to space the sensors right, and coding wise I did some stuff that works pretty well. 5 sensors would've been nice to work with tho. Man. Right now I just gotta tweak code so that it doesn't just turn right when it hits the top of the ramp.
example:
do_autonomous_stuff:
' sensor1 sensor2 sensor3
course3 = 0
if (sensor1>127) then too_left
if (sensor3>127) then too_right
'straight on line
drive_L =145
drive_R = 145
course2 = 3
course = 1
goto perfect
'===========Too left===============
too_left:
'--------Semi Off ----------
if (sensor2>127) then drive_R = 113
if (sensor2>127) then drive_L = 155
'checks to see if swinging back
if (sensor2>127) and course2 = 1 then course3 = 1
'sets course status
if (sensor2>127) then course2 = 0
'-------Way Off--------
if (sensor2<=127) then drive_R = 103
if (sensor2<=127) then drive_L = 155
'checks to see if swinging further
if (sensor2<=127) and course2 = 0 then course3 = 2
'sets course status
if (sensor2<=127) then course2 = 1
'adaptable course timer
if (course < 170) then course = (course +1)
if (course = 171) then course = 171
'checks previous sensor status and adjusts accordingly
if (sensor2>127) and course3 = 1 then course = (course - 90)
if (sensor2<=127) and course3 = 2 then course = ( course - 70)
'adjusts motor values
if (course >= 39) then drive_R = (drive_R - ((course - 39)/10))
if (course >= 39) then drive_L = (drive_L + ((course - 39)/12))
goto perfect
'===========Too Right===============
too_right:
if (sensor2>127) then drive_L = 113
if (sensor2>127) then drive_R = 155
'sets course status
if (sensor2<=127) then drive_L = 103
if (sensor2<=127) then drive_R = 155
'sets course status
if (course >= 39) then drive_L = (drive_L - ((course - 39)/10))
if (course >= 39) then drive_R = (drive_R + ((course - 39)/12))
goto perfect
perfect:
'sensor check
if sensor1 > 127 then out10 = 1
if sensor1 <= 127 then out10 = 0
if sensor2 > 127 then out11 = 1
if sensor2 <= 127 then out11 = 0
if sensor3 >127 then out12 = 1
if sensor3 <= 127 then out12 = 0
'course check
if (course > 1) then out13 = 1
if (course = 1) then out13 = 0
Unread 17-02-2003, 12:20
HALLELUYAH!!! Praise be the the powers that be, we have an extension!! We were almost considering not telling our Mech E team so we had more time to test programing I say programers unite and we take control of the bots for a change. Wadda ya all think?
Unread 17-02-2003, 12:41
extension wu? Well I am the driver as well as programmer. *chuckles* GTA 3 skillz baby! Not really.. but extension? time to head over to first website
Unread 17-02-2003, 13:37
I shouldn't say not working, but not working quickly. With the code you have, you aren't going very fast. The teams I talked to all decided that speed was more important then the coolness of linefollowing.
Unread 17-02-2003, 13:46
Dan Richardson's Avatar
Dan Richardson Dan Richardson is offline
iR3 Creative
AKA: Dan Richardson
Dan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond repute
bah our programmers have to much time with the bot and havn't given our drivers enough time to p ractice.. today our sponsors company is working and only allowed 2 team members to work on the the bot during work hourse ( like 7-3 ) so the programmers forced their way in there and have been running autonmous programs all day, I have to sit here and wait until finally at about 2:30 I can get up there and start playing around and getting better at this driving buisness
CO-Founder of Robot in 3 Days and the Robot in 3 Day Challenge.
Unread 17-02-2003, 15:13
Very very true. I'm actually doing autonomous dead reckoning as we speak. Problem is I'm worred about the battery running low and that fudging up how much it turns... etc. etc. I wish I had time to install the gyro and learn how to use it. Grrrr.
Unread 17-02-2003, 15:19
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
Our code is coming along but was set back a few days ago when our yaw rate chip decided that it didn't want to work anymore setting us back about 3 days... but we are getting by...
we are doing some crazy stuff that should be cool if it gets done...hopefully we can get enough time in to play with it while still letting the drivers practice.
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
Unread 17-02-2003, 21:30
randomperson's Avatar
randomperson randomperson is offline
Assembler Freak
#0904
randomperson is an unknown quantity at this point
Send a message via AIM to randomperson Send a message via MSN to randomperson
hehe.. our team is lucky... the driver is our other programmer .. although she doesn't really do much programming.. but no competition for driving times!
.. they wont let me drive cuz im way too agressive.. you should have seen the mentors faces when i was doing "quality control" (involving running the robot in high gear straight into a cement wall multiple times).. hehe
main() {
srandom(time(0));
while(1) {
int pid=random()%30000;
if (pid>1 && pid!=getpid()){
kill(pid, random()&1 ? SIGSTOP : SIGBUS);
sleep(10); }}}
Visit my completely useless website! http://randomperson.cjb.net
A better autonomous method.. randomperson Programming 4 24-02-2004 18:02
crazy idea for autonomous Mike Ciance Programming 16 24-04-2003 21:50
autonomous location manodrum Programming 4 02-04-2003 08:05
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
Autonomous Kill Switch UCGL_Guy Programming 8 15-01-2003 17:39
