Go to Post Don’t get caught in mindsets which will limit the potential that the future may hold. - Jaine Perotti [more]
Unread 23-02-2014, 01:06
JTN's Avatar
JTN JTN is offline
AKA: John Taylor Novak
FRC #0016 (Bomb Squad)
JTN has a reputation beyond reputeJTN has a reputation beyond reputeJTN has a reputation beyond reputeJTN has a reputation beyond reputeJTN has a reputation beyond reputeJTN has a reputation beyond reputeJTN has a reputation beyond reputeJTN has a reputation beyond reputeJTN has a reputation beyond reputeJTN has a reputation beyond reputeJTN has a reputation beyond repute
Re: Baxter Bomb Squad 2014 ~ Nighthawk
Originally Posted by Electronica1 View Post
Ok, I will take you up on that. How does your shooter mechanism work? Your robot was moving so fast I could not really get a good view of it.
Yeah, one of our points in the video is to kind of hide the robot internals to an extent, but I'm happy to explain a mechanism to you. At one point we used two of the legal van door motors and two Banebot 775 geared on Versa Planetary Gearboxes at 100:1. They drive sprockets that are connected to the camshaft at about a 1:2 gear ratio (I cannot remember the exact numbers here). The cams were machined out of 1/4" aluminum and slide onto a Vex Pro hex shaft that runs across the entire mechanism working as the camshaft. I have attached some images that depict the original shape of the cams as well as the mechanism as a whole on the practice robot. Of course, it being a practice robot, we have removed one set of our 3D printed spacers to shorten them down because they added a bit too much unnecessary stress to the mechanism as a whole but this is not an issue on the competition robot (which was built much better). The reason I said the original design of the cams earlier in the post was because we added one slight notch on each side that allowed the catapult to rest slightly when cocked to lessen the stress on the van door motors. We actually learned that it was possible to remove those two motors entirely (the 775s were doing all the work anyway) and the small notches prevent any possibility of back-driving. If you have any other questions relating to the details of the mechanism, feel free to ask; I'd be happy to answer them.
Originally Posted by Andrew Lawrence View Post
Beautiful machine. Your swerve seems a bit faster than usual - what speeds are you running it at?
It's not really all that faster, actually. The only change that was made was to switch a 12 tooth sprocket out for a 16 tooth so they could fit on a 1/2" hex shaft. The gearing farther down the line was changed to compensate (gearing was changed from 9.5:1 to about 9.3:1. The only real differences lie outside the drive train itself. This year's robot was designed to have an extremely low center of gravity (about 4" off the ground) which adds to an overall better drive base. Last year's robot was designed to have a 40 lb climber stowed away underneath, which when removed meant the robot was very tippy and had poor driving performance. Our 2014 robot also has improved programming for the steering modules (finding shortcuts for rotation of the wheels to prevent full 180 degree turns unless they are necessary, etc) and the parts were machined and assembled with a much higher standard in quality than in previous years. We really tried to put emphasis on building a finished product rather than what should be a complete prototype robot (we are currently fixing what would normally be our competition robot but is now our practice bot because we built two for this purpose). Our competition robot is built with an entire robot of experience behind us, so naturally it performs much better than even we expected of it!
P.S. To answer, we run at about 12-13 FPS in reality [geared for about 16 fps, but stress is a real thing].
Thanks for the questions, I hope I answered them fully! Please do not hesitate to ask any other questions about our robot, as we would be glad to answer them. I am more keen on answering mechanical questions and I'm sure Jefferson will be on top of any questions regarding the robot's programming time permitting.
-John Taylor Novak
They say I can't use a URL or BB code, so I'll use this for my signature.
Unread 23-02-2014, 01:37
Answer42's Avatar
Answer42 Answer42 is offline
Answer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud of
Wow. Hands down the most effective robot I've seen thus far.
My comments do not reflect the views of associated teams.
Unread 23-02-2014, 02:55
Meredith Novak's Avatar
Meredith Novak Meredith Novak is offline
no team (Arkansas FIRST)
Meredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond repute
Normal speed. JT driving like a maniac. Sad no one has mentioned our double BFLs.
Unread 23-02-2014, 07:30
TD78 TD78 is offline
AKA: Tom Dolan
FRC #0078 (AIR Strike)
TD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant future
great looking robot! love the swerve...your team is the best around that does it!
question about the intake...how does the wheeled shaft interface with the lexan "arms"? looks like the shaft goes into a metal plate, that is in turn attached to the lexan. chain or similar running down to the robot to the motor? any close up pictures available?
FRC78: 2010-Present
FRC121: 2002-2009
Unread 23-02-2014, 09:07
Jefferson Jefferson is offline
AKA: Jeff Clements
Jefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond repute
There is a 550 inside the beater bar. So all we have running up the arms are the motor leads.
Unread 23-02-2014, 10:58
jrl5595's Avatar
jrl5595 jrl5595 is offline
FRC #0706
jrl5595 is on a distinguished road
Wow. Best one robot I've seen so far. Awesome work
Unread 23-02-2014, 11:19
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
Awesome, awesome, awesome!
We "borrowed" from your 2008 ball pick-up design and it proved to be most effective at the pre-bag scrimmage. Thanks for the inspiration!
Have a great year and see you in St. Louis!
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
Unread 23-02-2014, 12:37
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
My only regret this season is I wont be able to see this robot in person. Another great robot by the Baxter Bomb Squad. I have seen all your robots in person since 2002, this one definitely beats all of them when it comes to efficiency and effectiveness.
Unread 23-02-2014, 12:44
Jibri Wright's Avatar
Jibri Wright Jibri Wright is offline
FRC #1781 (Electric Eagles)
Team Role: CAD
Jibri Wright will become famous soon enough
You can meet it in person if you make it to Nationals
You know someone likes something when after doing it a million times, they still marvel at it as if it was the FIRST.
Greatness asks how can I make it better. Genius asks how can I make it different.
Unread 23-02-2014, 12:55
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Nationals? What's that?
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 23-02-2014, 13:15
Andrew Lawrence
Posts: n/a
It's a fun American party.
Unread 23-02-2014, 14:30
JTN's Avatar
JTN JTN is offline
Thanks for watching! I'll try to explain my best on how the beater bar mechanism works. As stated before, we use a BaneBot 550 motor that is actually mounted inside the bar itself for protection, ease of design, lowered machining times, weight, and overall cleanliness. I have attached some pictures of our CAD model below that provide a visual representation on how we fit the motor in the beater bar and how we interface the drive shaft of the motor with the bar. We machined round inserts that fit into the bar and are screwed in from the outside with flat head screws that have a hole in the center with clearance for a key so they can slip on the output shaft of the stock 25.91:1 BaneBot gearbox (it may be a different gear ratio, but I'd have to look at it to make sure). The motor/gearbox combination is attached to the poly-carbonate strips by two 1/8" stainless steel plates that capture the motor and a small aluminum block that both holds the assembly together and attaches it to the poly-carbonate frame component. The other end of the beater bar is simply held on by a small machined part that fits into a ball bearing on one end and interfaces with the Lexan on the other end via two screws. For purposes of illustration, I made the beater bar transparent even though it uses our Baxter blue livery in the real world.
-John Taylor Novak
P.S: Unfortunately, I don't think I am able to give CAD models until the season is over due to the nature of the competition, but I'm more than happy to provide pictures of the models for a rough reference to the overall idea.
Unread 23-02-2014, 15:34
Team Role: CAD
Wow, that's quite a cool concept! The last time I've been this excited is when I found out how your swerve drive works Innovative ideas as always!
Unread 23-02-2014, 19:24
bEdhEd's Avatar
bEdhEd bEdhEd is offline
Design and Drive Team Mentor
AKA: Frank E.G. Shiner
FRC #0701 (The RoboVikes)
bEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond repute
That 3 ball autonomous mode is awesome! I hope my team gets to our goal of a 2 ball autonomous before our week 1 competition
Unread 23-02-2014, 19:43
Joining the 900 Meme Team
FRC #0079
Nice to see this thing finally public. Hopefully I'll be able to stick my head inside and talk swerve with you guys at CMP this year.
