Go to Post When mentors and students battle it's the team that loses. - Koko Ed [more]
Unread 21-02-2014, 10:03
Tem1514 Mentor's Avatar
Tem1514 Mentor Tem1514 Mentor is offline
FRC #1514
Tem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to behold
BCD switch programming
I am looking for a little insight on how to program a number of different autonomous functions by using a BCD (binary coded decimal) switch that will provide 0-9 out to the digital sidecar.
Let us assume that the BCD switch is wired to bits 5 thru 8 on the side car with bit 5 as LSB and 8 as MSB.
My question(s) are when using C++;
1) how do you mask out only the BCD to have a “more useful number”?
2) To select any one autonomous mode would you use ‘IF’s’ or ‘Case’ statements?
It would be real nice to see some sample code for this as I’m sure it go a long way for other teams as well.
Even better would be examples using C++, Java and Labview.
I sure hope that Alan will jump in on this one
Unread 21-02-2014, 10:17
Sparkyshires Sparkyshires is offline
AKA: Michael Shires
FRC #0384 (Sparky)
Sparkyshires is an unknown quantity at this point
Re: BCD switch programming
Have you looked at the digital inputs on the driver station? Our team uses those exclusively for deciding which autonomous we're going to use. Last year we had 7 different autonomi xD And we use a big 'if' statement, with the arguments looking something like this:
if(ds->GetDigitalIn(1))
	//Autonomous1
else if(ds->GetDigitalIn(1))
	//Autonomous2
etc.. This is a simple way to do it. You could also use a switch-case statement, would definitely be one of the few uses in robot programming to use it. The only reason we don't is just that switch-case statements are so rarely useful in FRC programming that we normally forget about them you would have to pass your switch case variable as an argument in the GetDigitalIn function.
"Measure with a micrometer, mark with chalk, cut with an axe."
Unread 21-02-2014, 10:32
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
BCD is a limited subset of a hex nibble (single hex character). You can do that using bit shifts:
uint8 temp = getDigitalIn(#);
temp |= (getDigitalIn(#)) << 1;
temp |= (getDigitalIn(#)) << 2;
temp |= (getDigitalIn(#)) << 3;
//Now temp is a number from 0x00 to 0x0F
The lower levels of the WPIlib access the Digital Inputs as a single uint16 from the FPGA. If you wanted to poke and find the function to read those, you could just apply a mask and bitshift to get your number, instead of creating 4 dio objects and reading all of them (much less code, more efficient):
uint16 auton_num = <get the 16 bit DI register>;
auton_num &= 0x00F0;
auton_num = auton_num >> 4;
In LV, we use the auton number to index a 2d array of auton types (a struct of an array of strings and a command number). The first index is the auton, the second is time (when the command returns True, it advances to the next element in the array on the next iteration). The array is populated on boot by reading text files and parsing them. The array of strings are arguments, which functions read numbers out of on the first call.
Kettering Motorsports
Unread 21-02-2014, 14:10
chris.boyle's Avatar
chris.boyle chris.boyle is offline
Programming Mentor
FRC #0068 (Truck Town Thunder)
chris.boyle is on a distinguished road
I'm enclosing two examples of how we have done what you are asking for.
DIORead.png:
This is how we read the BCD number wheel on our 2012 robot. This number was used to select which autonomous to execute. We used the Analog Inputs on the Driver Station to set our start up delay before the Autonomous started.
AutonRead.png:
We changed to a text based command structure for autonomous in 2013. The Selection was chosen on the Dashboard and read at the start of Autonomous Independent.vi and passed to this VI. This VI read T3-Auton.ini (we used ftp to copy it to the cRIO) and selected the Section to read and execute. Below the code is a small subset of the T3-Auton.ini file. It also posted the command it is currently executing to the Driver Station User Message Window
ID:	16352  Click image for larger version
2014 Chairman's Award--Michigan State Championship
2014 Chairman's Award--Waterford District
2014 Winner--Great Lakes Bay District
2013 Chairman's Award--Kettering District
2012 Championship Division Finalists--Thanks 330 and 639
Unread 22-02-2014, 01:41
SoftwareBug2.0's Avatar
AKA: Eric
FRC #1425 (Error Code Xero)
A quick grep of the 1425 2014 robot code reveals 67 switch statements. Do you code your state machines with a bunch of "if" statements?
Unread 22-02-2014, 10:47
apalrd's Avatar
More Torque!
VRC #3333
I use LV, so a Case Structure is the same a both an If and a Switch. There's also a Select, which picks one of two inputs based on a boolean input. In normal programming (in C), I use Switch/Case all the time, usually for states.
FOR loops, on the other hand, have very limited use in controls programming. In general, you can use something else (such as a ratcheting counter) where a lot of new programmers use For loops and history buffers.
Unread 24-02-2014, 09:25
AKA: Michael Shires
FRC #0384 (Sparky)
Yeah we do, with boolean values holding the state of most mechanism on the robot. I'm being a bit dense, but I fail to see how a switch case could be used for that.
Unread 24-02-2014, 10:56
apalrd's Avatar
More Torque!
VRC #3333
If you need more than two states, you could use an unsigned integer or enum (which is effectively a uint with names) and a Switch through all of them.
For example, a shot sequencer last year had three states: idle, fire_execute, and fire_retract. It transitioned in a 'circle', with a condition from idle to fire_execute (fire trigger input), two conditions to return from fire_execute to fire_retract (gun speed accel threshold met, or failure timer met) and a timer to return to idle (shot interval reset timer). We could represent this with the following C code:
typedef enum {
stIDLE,
stFIRE_EXECUTE,
stFIRE_RETRACT
} fire_seq_t;
fire_seq_t state = stIDLE;
/* Somewhere in a temporal task */
switch(state) {
 case stIDLE:
  if(FIRE)
   state = stFIRE_EXECUTE;
 output_piston = 0;
 break;
 case stFIRE_EXECUTE:
  if(GSA_TRIG || TIMER > FIRE_FAIL_TIME)
   state = stFIRE_RETRACT;
 output_piston = 1;
 break;
 case stFIRE_RETRACT:
  if(TIMER > RETRACT_TIME)
   state = stIDLE;
  output_piston = 0;
  break;
Unread 24-02-2014, 14:55
AKA: Michael Shires
FRC #0384 (Sparky)
Thats really neat! I'd never used enums before, I might use them next year The thing is that I would have used int's, but on the robot this year, almost every mechanism has boolean values, as we're using a fair amount of pneumatics. What it would have been helpful for is the shooter, as we're forced to put that in two variables, one for cocked and ready to shoot, and one for whether or not you have a ball.
Unread 24-02-2014, 15:13
apalrd's Avatar
More Torque!
VRC #3333
Enums are awesome.
I have only used them in C and LV, I don't know about implementation other languages like Java. In both C and LV, they are represented as uint's, so you can do integer math and table lookups using it as well (e.g. we frequently have an array of setpoints, which we index by the state).
In the 'real world', I've seen people implement things with registers full of boolean bits, e.g. one program had things like GENFGA, GENFGB, GENFGC (gen flags A,B,C..Z and 1..9), each an 8 bit register full of bits relating to stuff, and the software is very bit-flag centric. IMHO, a numerical state machine is easier to understand.
Unread 27-02-2014, 07:27
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
Enums are really useful. Here's a good example from our 2013 code of a command that supervises a subsystem on the robot, with several states represented by enum values:
https://github.com/stevep001/RoboEag...sorCommand.cpp
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
