Go to Post "He who seeks originality will often find novelty, but not great design." - IKE [more]
  #31   Spotlight this post!
Unread 23-02-2014, 21:56
Canon reeves Canon reeves is offline
FRC #4490
Canon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud of
Re: Baxter Bomb Squad 2014 ~ Nighthawk
wow, now this will make Arkansas regional even more interesting! Can't wait to watch yall drive circles around us and most of the other robots again! It really looks great, yall did a really good job this season. How did I know that yall would do a catapult? Gut feeling I guess?
  #32   Spotlight this post!
Unread 24-02-2014, 08:53
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
This Bomb Squad machine looks to be one of your most competitive yet. Thanks again for the inspiration on the intake, FRC558 is running a polycarbonate armed, motor in roller, intake as well this year.
  #33   Spotlight this post!
Unread 24-02-2014, 09:12
Rob Stehlik's Avatar
Rob Stehlik Rob Stehlik is offline
FRC #0610 (Coyotes)
Rob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of light
Originally Posted by JTN View Post
The reason I said the original design of the cams earlier in the post was because we added one slight notch on each side that allowed the catapult to rest slightly when cocked to lessen the stress on the van door motors. We actually learned that it was possible to remove those two motors entirely (the 775s were doing all the work anyway) and the small notches prevent any possibility of back-driving.
-John Taylor Novak
Nice to see another cam based catapult! We came up with a different solution to back driving that you may be interested in: The final 30 degrees of our cam profile is circular, so there is no reaction torque from the catapult springs. Once the cam follower gets to the circular part of the cam, there is no chance of back driving.
As a side note, we built a small cam driven catapult last year for a non FRC project, and experimented with a notch in the cam to prevent back driving. It worked, but we found there to be a large current spike when the motor was trying to get the follower out of the notch.
  #34   Spotlight this post!
Unread 24-02-2014, 09:29
Jefferson Jefferson is offline
AKA: Jeff Clements
FRC #0016 (Bomb Squad)
Jefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond reputeJefferson has a reputation beyond repute
The reliability and repeatability of the cam driven catapult was the deciding factor for us.
We had a similar profile you describe, just not as long on the flat. Hitting that small window right before the roll over was tough. We also like the idea of being mechanically locked in there.
We do get a pretty significant current spike coming out of the notch. I watched our practice bit spike over 60A the other night. It took us several rounds to get the slope flat enough come back out to reliably fire.
Btw, y'all's robot looks very nice again this year. Good luck out there.
  #35   Spotlight this post!
Unread 24-02-2014, 10:11
AKA: Jeff Clements
Originally Posted by Andrew Schreiber View Post
Nice to see this thing finally public. Hopefully I'll be able to stick my head inside and talk swerve with you guys at CMP this year.
Please do. Nothing I like more than to geek out over swerve drive for a while.
  #36   Spotlight this post!
Unread 24-02-2014, 10:19
Joining the 900 Meme Team
FRC #0079
JT was mentioning you guys had some issues with Command Based robot stuff last year, care to elaborate?
And, I'll absolutely come over and geek out.
  #37   Spotlight this post!
Unread 24-02-2014, 11:42
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
There is a 550 inside the beater bar. So all we have running up the arms are the motor leads.
We also have Polycarb arms and inserted the motors inside the acquisition tube. I was wondering if anyone else would do this. See ya at QCR!
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
  #38   Spotlight this post!
Unread 24-02-2014, 12:34
AKA: Jeff Clements
I wouldn't say we had issues, but we definitely didn't use commands this year. They overcomplicated the small tasks and made the more complicated tasks very difficult. Especially where we needed more time resolution than whatever cycle the commands were on. The compile time for that many objects was hard to stomach also.
Our 2013 code is up here if you want to see how we inplemented commands:
https://github.com/FRCTeam16/TMW2013
I guess we are using commands one place this year, dashboard buttons. We have two or three things we need to do infrequently enough that don't need to be accidentally pressed on the joystick. Commands make that very easy.
  #39   Spotlight this post!
Unread 24-02-2014, 12:47
AKA: Jeff Clements
Yeah, the Lexan arms may look floppy and less "industrial" than rigid ones, but there's good reason we've had essentially this in 2008, 2010, 2012, and 2014. I'm beginning to see a pattern...
  #40   Spotlight this post!
Unread 24-02-2014, 13:19
FRC #0079
Our 2013 code is up here if you want to see how we implemented commands:
Interestingly, I felt similarly when I tried to use CPP for commands last year. Since switching to Java I found Command base was fairly simple and it meant a good chunk of our code was much cleaner than comparable other methods. I know it has allowed us to iterate our code far faster. I'll have to dig into this code and take a look at your new code at CMP this year.
Of course, my day job is primarily ruby/javascript code so that could explain why CPP felt less intuitive.
  #41   Spotlight this post!
Unread 24-02-2014, 14:47
Bryce2471's Avatar
Bryce2471 Bryce2471 is offline
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Bryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud of
Could you provide some details about your swerve drive design? Such as wheel size, steering gearing, drive gearing, slip rings, or coaxial.
Our team did independent swerve drive for the first time this year.
Thanks in advance.
FLL Team Future imagineers
2010 Oregon State Championships: Winners
2011 International Invite: First place Robot design, Second Place Robot Performance
FRC Team Mean Machine
2012 Seattle: Winning alliance
2013 Portland: Winning alliance
2013 Spokane: Winning alliance
2014 Wilsonville: Winning alliance
2014 Worlds: Deans List Winner
  #42   Spotlight this post!
Unread 24-02-2014, 16:53
Meredith Novak's Avatar
Meredith Novak Meredith Novak is offline
no team (Arkansas FIRST)
Meredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond reputeMeredith Novak has a reputation beyond repute
Just make sure the catapult is disabled before you stick your head in...that thing really scares me!
  #43   Spotlight this post!
Unread 24-02-2014, 16:55
FRC #0079
I'll avoid standing on it while it's loaded too.
  #44   Spotlight this post!
Unread 24-02-2014, 16:56
I have pictures. JT better stay clear of safety judges.
  #45   Spotlight this post!
Unread 24-02-2014, 17:08
JTN's Avatar
JTN JTN is offline
AKA: John Taylor Novak
JTN has a reputation beyond reputeJTN has a reputation beyond reputeJTN has a reputation beyond reputeJTN has a reputation beyond reputeJTN has a reputation beyond reputeJTN has a reputation beyond reputeJTN has a reputation beyond reputeJTN has a reputation beyond reputeJTN has a reputation beyond reputeJTN has a reputation beyond reputeJTN has a reputation beyond repute
Thanks in advance.
Our swerve drive uses slip rings mounted at the top and we use 6" AndyMark performance wheels. I have some CAD models of our 2013 drive train if you'd like to see. Our output gear ratio is about 9.5:1 on the drive and for steering we use AM 9015s geared down using Versaplanetaries from VexPro (I'll have to figure out the gearing of that when I go to the shop later today). Here are some pictures of the model for a more visual approach. If you have any other questions, please don't hesitate to ask. Just send me a PM asking for the gear ratios for the steering and I'll try to get them to you as quickly as possible.
-John Taylor Novak
They say I can't use a URL or BB code, so I'll use this for my signature.
