Go to Post WAIT WAIT, I GOT IT!!!! What if.... it's just a picture of a fish. - Libby K [more]
Unread 24-02-2014, 11:36
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Pre-charging pneumatic system
Add 20-45 minutes if you're told to be on the field for opening ceremonies. Add an hour if it's champs.
GitHub
Unread 24-02-2014, 18:55
DonRotolo's Avatar
Back to humble
FRC #0832
1 PSI per minute is a bit high. 10 PSI per minute is cause for panic!
Make up a weak solution of soapy water and paint it onto each and every fitting. Bubbles will point to the leaks very quickly.
Unread 24-02-2014, 19:48
Jarren Harkema's Avatar
Jarren Harkema Jarren Harkema is offline
Dancing Drive Coach
FRC #4967 (That ONE Team)
Jarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to all
Ouch! I didn't realize how bad that is! I will definitely be pushing for curing those leaks during our robot access period. Thanks everyone!
Unread 24-02-2014, 20:19
Pendulum^-1's Avatar
Pendulum^-1 Pendulum^-1 is offline
AKA: Jim Grove
FRC #1915 (Firebird Robotics)
Pendulum^-1 is just really nicePendulum^-1 is just really nicePendulum^-1 is just really nicePendulum^-1 is just really nice
When I teach a team new to pneumatics, I emphasize that each component should be leak checked extensively before installing it on the robot. I know that this advice is a bit late for your 2014 robot, but it has helped out team immensely over the years. As we typically check each component a week or two prior to installation, final installation is typically a function of hooking up the hoses, and doing a final pressure check.
Jim Grove, Mentor
firebirds1915.blogspot.com
(2007-2017) 1915, McKinley Tech HS, Washington, DC
(2009) 2932, Mid-Pac Institute, Honolulu, HI (Rookie Season)
(2011) 2425, Hillsborough HS, Tampa, FL
(2013-2015) 4464, College Park, MD, 2013 Rookie All Star Winner and 2014 Regional Champions, Washington, DC
FIRST is not rocket science. But it is like drinking from a fire hose.
Unread 24-02-2014, 20:33
Tem1514 Mentor's Avatar
Tem1514 Mentor Tem1514 Mentor is offline
FRC #1514
Tem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to behold
One very common place that many teams overlook is the Festo screw in fittings that seem just impossible to make tight from the outside. The trick is to insert the correct size metric allen key into the fitting to allow you tighten the fitting to the body.
