Go to Post Problem with microprocessors: they do exactly what you tell them to do - KenWittlief [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > Scouting
Unread 22-02-2014, 18:06
Dragonking's Avatar
Dragonking Dragonking is offline
AKA: Aaron Cannon
Dragonking is just really niceDragonking is just really niceDragonking is just really niceDragonking is just really niceDragonking is just really nice
paper: 2014 Scouting Database team 862
Many improvements and changes. Make sure to READ THE INSTRUCTIONS in the database. There is a 3 minute calculation time every time you input data. The database is set to manual calculation so press F9 after you have inputted a large amount of data to calculate. Press Shift+ F9 to just calculate a single sheet. The scouting sheet workbook is used for scouting with tablets and will work with most spreadsheet apps. You can also input data manually if you can't get access to tablets. You can base your paper scouting sheets off the digital one. If you have any questions, read the instructions, then feel free to ask me in this thread or pm me.
Unread 24-02-2014, 16:24
Dragonking's Avatar
AKA: Aaron Cannon
Re: paper: 2014 Scouting Database team 862
Sorry for the delay, it seems to take a while to upload to chief delphi.
Here are the links to the database and the scouting sheet. Let me know if you can access them.
database: https://drive.google.com/file/d/0B7h...it?usp=sharing
scouting sheets: https://drive.google.com/file/d/0B7h...it?usp=sharing
2013-2014 Mechanical Subgroup, Scouting Captain
2015 Design Subgroup, Strategy Lead/Scouting Captain
Unread 24-02-2014, 17:31
Dragonking's Avatar
AKA: Aaron Cannon
Comments and questions are welcome.
Unread 25-02-2014, 16:21
Dragonking's Avatar
AKA: Aaron Cannon
It is now uploaded on chief delphi. It is zipped.
Unread 04-03-2014, 22:26
Dragonking's Avatar
AKA: Aaron Cannon
New scouting sheet added- uses buttons for input but requires a program that runs excel vba macros. (for android use "AndrOpen Office")
Soon I will release an updated database that will run much faster than the first one. (less that 5 second calculation time)
Field diagrams were removed temporarily- I hope to add them to the system again in the next update.
Unread 05-03-2014, 08:32
Just curious... what calculations are you doing that require 3 minutes to complete?
Unread 05-03-2014, 16:33
Dragonking's Avatar
AKA: Aaron Cannon
I had a lot of volatile functions that at that point I couldn't replace with other functions. They will be removed in the next update. I will continue to improve the system throughout the season.
Unread 09-03-2014, 18:23
Dragonking's Avatar
AKA: Aaron Cannon
Updated scouting database posted. It is faster (only half second calculation), and some parts are simplified. I removed the field diagrams for now. There is currently only manual input (still working on the tablet scouting sheet and programming).
Unread 27-03-2014, 15:19
Dragonking's Avatar
AKA: Aaron Cannon
New scouting database and scouting sheet along with improved tablet scouting system.
Unread 07-04-2014, 19:14
Dragonking's Avatar
AKA: Aaron Cannon
New update- some bugs fixed
Unread 15-04-2014, 19:12
Dragonking's Avatar
AKA: Aaron Cannon
new update-more bugs fixed, added new feature in eliminations tab-makes it easier to keep track of match scores in elims
[IMG] code is Off
